11-25-2014, 05:17 AM   #1
old4570's Avatar
M42 adapter
I would like to try some lens stacking ( one lens in front of the other ) , for some serious Macro .
Anyhow , I was thinking of the M42 lenses ..
And how if you put on a lens adapter ring you could simply then screw the M42 lens in front of another ( filter thread )
So I was wondering ( after checking the net - ebay etc ) , does such a simple animal exist ???
I would love a M42 adapter that screws into a 49mm - 52mm - 55mm - 58/62mm filter thread ..
11-25-2014, 05:30 AM   #2
photolady95's Avatar
Location: Cruising PentaxForums and watching your back.
I think your best bet to enable you to mount another lens to the M42 lens would be a step ring. Use the adapter as you usually would to mount the initial M42mm lens, then use a step up ring to mount another lens to the M42 lens.
11-25-2014, 05:43 AM   #3
old4570's Avatar
Hmmm
I think I found two :
52mm to 42mm 52 42 M42 Filter Adapter Ring | eBay This one
Reversing Ring 49mm M42 Screw Mount 49mm M42 Reverse Reversal Ring Made in Japan | eBay I have no idea on this one ?
Im going to buy the first as it looks to be whats needed , it can then be stepped up or down ..
11-25-2014, 05:48 AM   #4
what you need know is a m42 variable tube
Unexpectedly I just received one in a random job lot.
I suspect you will need to synthesize the registration distance to maintain focus - but that is a guess.
11-25-2014, 05:49 AM - 1 Like   #5
Not a Number's Avatar
When "stacking" lenses for macro you mount them filter ring to filter ring. So all you need is a filter coupling reverse ring - male filter threads on both ends. Lenses on either end can be of any mount. You can get them in various combinations of filter diameter.
Magnification is roughly dividing the focal lengths. Such as a 100mm with a 50mm lens reversed on it would be 2:1 (2x).
These should not be confused with the lens mount reverse adapters which have male filter threads on one end and the appropriate lens mount on the other.
This first ring you linked won't work for what you want to do. The rear elements of a screwmount lens protrude to far and the thread pitch is probably wrong.
The second adapter is the lens mount reverse adapter mentioned above. This is used with a single lens mounted reversed to the camera body.
You want something like this:
http://www.ebay.com/itm/Filter-Coupling-Reverse-Ring-Adapter-for-52mm-to-52m...item1e89ecd4b9
See this thread for ideas and an explanation of reverse stacking.
https://www.pentaxforums.com/forums/54-pentax-lens-articles/152336-cheap-macr...lose-work.html
11-25-2014, 03:40 PM   #6
old4570's Avatar
I have coupler rings , .....
But last night I was looking through some old mould infested lenses ( given to me , and I haven't thrown them out as I have a task for them )
And I noticed it did not really matter if the stacked lens went forward or backward , to the naked eye ..
So to experiment , I thought M42 might be choice ..
Just my need to experiment ...
11-27-2014, 12:30 AM   #7
QuoteOriginally posted by old4570 Quote
According to the Pentax Auto Bellows A manual:
Figs. 1 to 3 refer to the Macro 50mm lens. The lens has been designed for focusing with "a" larger than "b" which is the case for ordinary photography as in Fig. 1. So it is only natural that optimum sharpness when photographing larger than life size, as in Fig. 3, is achieved with the lens reversed.
When the lens-to-film distance of any lens is twice the focal length of the lens, as show in in Fig. 2 on the next page, the photographic magnification will be 1× (life size).
adapter, camera, filter, front, lens, m42, pentax help, photography, thread, troubleshooting
Genuine Pentax Mount Adapter B or M42 To K adapter SANDY1977 Pentax Camera and Field Accessories 9 06-22-2013 02:41 PM
m42 adapter mods ChatMechant Pentax SLR Lens Discussion 8 02-23-2013 02:05 PM
For Sale - Sold: Pentax Mount Adapter K (M42 adapter) séamuis Sold Items 2 07-12-2012 05:50 AM
M42 Adapter stuck on M42 lenses glee46 Troubleshooting and Beginner Help 31 11-29-2011 05:16 AM
what m42 adapter for 5d mk1? fikkser Non-Pentax Cameras: Canon, Nikon, etc. 5 09-15-2011 07:43 AM
All times are GMT -7. The time now is 01:34 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
