11-26-2014, 07:25 PM   #1
K20 Manual Setting: automatically adjusting Aperture & Shutter speed together
My K20D Pentax recently started to have issues operating in Manual mode. About 50% of the time when I am adjusting the aperture, it'll automatically adjust the shutter speed as well and vice versa. It's as if the camera is on Mode P, but I can still see the light meter adjusting. Other modes seem to work fine. Same story regardless of what lens is being used. Formatting and reseting have not fixed the issue. I am not familiar enough with this camera to know what else may be causing the issue.
11-26-2014, 08:31 PM   #2
MarkJerling's Avatar
If you press the green button, the camera will auto correct. Without using the green button, it should not auto correct.
11-26-2014, 08:43 PM   #3
ChristianRock's Avatar
That is very odd... I wonder if it's worth re-installing the firmware.
11-26-2014, 10:17 PM   #4
Just1MoreDave's Avatar
Does an asterisk show up in the displays when this happens? On the rear LCD, it would be at the top of the screen, on the right hand side. In the viewfinder, it's on the bottom, right side, left of the counter for images remaining on the card. If that's true, your AE-L button might be sticking or getting inadvertently pressed.
aperture, camera, issue, k20d, manual setting, mode, pentax help, photography, shutter, shutter speed, troubleshooting
aperture, shutter speed settings wetigers Troubleshooting and Beginner Help 8 05-12-2014 10:44 AM
Setting minimum shutter speed? yakky Pentax K-30 & K-50 5 12-08-2013 09:33 AM
K20D & setting shutter speed UpNorth Pentax DSLR Discussion 8 01-09-2009 10:11 PM
Setting the shutter speed AND aperture on the K10D Photogoof Pentax DSLR Discussion 3 03-28-2008 03:19 PM
smc M lens and adjusting shutter speed slip Pentax DSLR Discussion 11 03-21-2007 07:21 PM
All times are GMT -7. The time now is 10:20 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
