Originally posted by Not a Number It shouldn't be asking for credentials unless it needs admin rights to run on your login or it needs to attach files on a networked or shared drive.
I would suspect you still have a virus or malware on your system. Did you clean the virus on your own or did you seek assistance from a site like dslreports.com or majorgeeks or the like? If you did it on your own I would suggest running a least three different virus scanners especially those that will boot into Linux to run the scan.
If you are absolutely certain your system is clean perhaps try running (on Windows) the PDCU 4 as an administrator.
I just ran a major scan by majorgeeks website(thanks) and there doesn't seem to be any problems with viruses. I tried running the program as an Administrator, checked the compatibility under other operating systems, tried to open a RAW file with the program. Nothing seems to work. If I hit the OK button on the Login box I get a message stating "unknown Format for file PTXUTL.mdb" ? Luckily I can still use Lightroom and Photoshop Elements which are much faster to open and edit my images but it sucks since I paid for the Pentax Utility. Contacting Pentax is a waste of time even if I could because they only work during normal business hours I can see the look on my bosses face while trying to solve an issue like this on the job.
