Originally posted by KarenAmelia I miss the relative simplicity of the old film SLRs,
Assuming you mean the old manual film SLRs like the K1000, then you can theoretically use your K5 in a similar fashion. If you set your mode dial to M, then you can set your F stop and Shutter speed with the front and back wheels ( I think you can configure which one controls which function via the menus ). You can set your ISO manually, just as you would on an old film SLR. White balance is something you would not have had access to in a film camera - either set it according to your lighting conditions or leave it on auto.
Turn off auto-focus via the switch on the front of the camera if you want to manually focus, but the focus screen won't be as good for that as the split prism focus screens they had in the old film cameras. From there, you can enable as little or as much automation as you like or are comfortable with. Set yourself a target of learning one new option per week ( or per day ).
There are obscure options/functions that to this day I do not know how to use on my own DSLRs. Every once in a while, somebody mentions something I was unaware of in a forum posting and if it sounds interesting or useful, I give it a try.
And the nice thing about your DSLR is that you don't have to wait to get your film processed - you can instantly check to see what effect the settings you selected had on the image. Flubbed shots don't cost you anything.
You don't have to jump into the deep end day one.
