11-29-2014, 09:41 PM   #1
Image not saved
Hi,
I was recently taking photos with my K-r and using a RawSteel 8Gb SD card. I could review the photos in the lcd, even see multiple images on the lcd, but when I turned the camera on later that day no images were available in the LCD. Reviewing on my computer showed the folder for that date existed but is empty. There are 7Gb free on the card, less than 200 images from the previous week on the card.
This seems the same issue as https://www.pentaxforums.com/forums/115-pentax-k-5/143493-photos-not-being-saved-card-fault.html. But that's a 3 year old post.
I have scanned the card using PandoraRecovery and Recuva, but only found 1400 old deleted images. This is different than the link above where most people affirm they have been able to recover the files. The card has been working well for years. After noticing the images were not available, I replaced the card to avoid any chance of overwriting due to a corrupted FAT table.
Worst part, photos were in Yosemite.
Any ideas?
thanks.
11-30-2014, 01:55 AM   #2
LensBeginner's Avatar
Stupid, idiotic question, but worth asking nonetheless...
Did you by chance format the card in camera wanting to restore factory settings?
I've found the wording in the menu to be ambiguous.
It looks like a formatting to me, if you could see everyhting and then nothing at all...
The presence of the folder could be explained if it were the default one(s): DCIM and 100_xxxx (at least on a K-01, unsure aboutthe K7... are you sure the date matches?
11-30-2014, 11:26 PM   #3
After more work, the issue was solved with chkdsk /f to locate and restore lost clusters. So somehow the FAT table got corrupted when deleting the older photos to make room for this trip.
As that linked post writes, it most likely would have been better to format before the trip and not rely on deleting and 'safely remove hardware'.
12-01-2014, 01:19 AM   #4
QuoteOriginally posted by SoccerGeek Quote
Glad you sorted it!
camera, card, images, k-r, lcd, pentax help, photography, photos, sd card, troubleshooting
Why does a saved image come out like a thin line? slackercruster Digital Processing, Software, and Printing 8 04-10-2012 11:21 AM
Photos Not Being saved To Card - Fault? sonny2962 Pentax K-5 14 05-11-2011 01:10 AM
K200D broken - Mirror stays up, picture not saved cfraz Pentax DSLR Discussion 3 03-22-2010 08:54 PM
Final Saved Image eco1 Digital Processing, Software, and Printing 11 01-17-2010 12:38 AM
Image not saved? kateowenjones Troubleshooting and Beginner Help 4 02-08-2009 03:34 PM
All times are GMT -7. The time now is 01:43 PM. | See also: NikonForums.com, part of our network of photo forums!
