12-03-2014, 10:37 AM   #1
How to use my SMC 1:2 50mm
Hi all,
I'm having a problem with my SMC 50mm lens. It was working fine before, but now when I turn it on (either on Manual, Program, etc.), it's only allowing me to adjust the shutter speed but not the aperature. I used it previously and had no issue. Thanks for any help :-)
12-03-2014, 10:47 AM   #2
Not a Number's Avatar
Is it an "A" lens? Set the aperture ring back to "A". There is a small release button on the aperture ring. Assuming body is a Pentax DSLR enu settings should be "Enable use of aperture ring", Green button in M and TAv mode to Tv shift, DOF preview to optical. Wording or features will differ depending on which body you have.
12-03-2014, 10:53 AM   #3
Thanks. I have a K-3. I have the ring already set to A. It worked fine before, but something is clearly different now and it won't let me adjust aperture.
---------- Post added 12-03-14 at 12:13 PM ----------
After I turn on the camera and select 50mm, it just says 'F--' where it typically displays the aperture reading.
12-03-2014, 11:24 AM   #4
Hogdriver's Avatar
Suggest you carefully clean the entire ring face (connections) on both your lens and camera.
I had the same issue once and cleaning resolved it.
Hope it works and gets you back to taking pictures.
12-03-2014, 11:28 AM   #5
QuoteOriginally posted by Hogdriver Quote
Awesome! Yup, that did it. Thanks so much :-)
50mm, aperture, body, button, camera, pentax help, photography, smc, troubleshooting
Companion to my SMC 50mm 1.4? strangeboy Pentax SLR Lens Discussion 17 03-07-2013 09:48 AM
Pentax K-x and Pentax SMC-Takumar 50mm f1.4 - How to use them together? voyager13 Troubleshooting and Beginner Help 5 04-27-2012 08:29 AM
how to use Super Takumar 1:1.4 50mm icy Pentax SLR Lens Discussion 20 12-11-2011 04:34 AM
My A 50mm 1.2 is Castrated! How to Proceed? Skyntara Pentax SLR Lens Discussion 28 02-02-2010 11:36 AM
How to use smc pentax-m 1:2 50mm lens with my K110D Hurricane510 Pentax SLR Lens Discussion 1 09-16-2009 12:06 PM
All times are GMT -7. The time now is 03:58 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
