12-03-2014, 01:30 PM   #1
Battery Grip batteries
My K-3 and battery grip arrived an hour ago. Not sure if I'm reading this right but my question is is it OK to use rechargeable AA batteries in the grip and then as I skim through the threads it looks like if I don't use a fully charge Lithium Ion camera battery in the grip the camera develops a floppy mirror syndrome....as if the electromagnets for the mirror actuator do not have enough juice to properly operate the mirror. Is this true?
If AA batteries are OK to use can you recommend which ones work the best?
Thank you?
12-03-2014, 01:34 PM   #2
Docrwm's Avatar
Congratulations on your new camera! I love that new camera smell!
For the K-5 and K-5iis Eneloops have worked fine for me in the grips. Not sure if the K-3 is behaving differently. They do last a far shorter time than the regular battery. BTW, I recommend the Washabi batteries for the Pentax 90 because they last as long in my experience, are FAR less expensive, and come in a 2 pack with folding prong charger (much easier IMHO than the Pentax corded charger) thus giving you 3 batteries and 2 chargers for around $26 from Amazon.
http://www.amazon.com/Wasabi-Power-Battery-2-Pack-Charger/dp/B004UR7250/ref=...bi+battery+K-5
12-03-2014, 01:39 PM   #3
Otis Memorial Pentaxian
QuoteOriginally posted by BlakeShellman Quote
No. The runaway mirror problem is not directly related to batteries or use of the grip.
Conventional wisdom is that Eneloops are the go-to battery for rechargeable AA with quality alkaline cells or single-use Li as the non-chargeable options.
---------- Post added 12-03-14 at 12:42 PM ----------
QuoteOriginally posted by Docrwm Quote
Yep..the price is competitive with a pack of Eneloops + charger.
12-03-2014, 01:44 PM   #4
Docrwm's Avatar
And I find them more convenient since you need 6 Eneloops for the tray (or has that changed for the K-3?).
12-03-2014, 03:34 PM   #5
OK...how about this? I'm going to buy another Pentax 90 battery. My other thought is to use the rechargeable AA batteries in my Pentax 540 flash. Are rechargeable OK for the flash also or is there another preferred battery type for the flash?
12-03-2014, 07:50 PM   #6
I don't remember. I had the grip for a couple of weeks before I sold it, but never tried the AA adapter. But wait! I just checked online and it does take six (6) AAs. That is a heavy load of batteries.
12-04-2014, 07:57 AM   #7
Oldbayrunner's Avatar
Yes rechargeable batteries are fine with the Af 540fgz. If your going to use the grip you might consider changing your battery selection setting from auto to grip 1st. Once the battery depletes in the grip then it will switch to the full battery in the camera instead of drawing from both at the same time.
12-04-2014, 10:13 AM   #8
Docrwm's Avatar
QuoteOriginally posted by Oldbayrunner Quote
Plus its easier to access the grip battery in the field. Good point!
12-27-2014, 06:05 PM   #9
kshapero's Avatar
If I am in an extreme situation (ie in the field) how many actuations can expect to get from 6 AA alkaline batteries in the grip of my K-5iis?. No Flash use.
---------- Post added 12-27-14 at 08:13 PM ----------
Also would the AA batteries in the grip work if the regular battery in the camera body was exhausted of a charge?
12-27-2014, 07:06 PM   #10
Banned
QuoteOriginally posted by kshapero Quote
Never used AA's until they were run down, so I have no idea how long they may last. I did however use only AA's in the grip of the K3 while the L-ion battery charged when I first got it. I would think they'd work as the only power source in the K5's as well.
12-27-2014, 07:38 PM   #11
Docrwm's Avatar
With descent AAs off the shelf - perhaps a 100 or so as I recall, although its been 2-3 years. My recollection is that there must be an actual battery in the camera but its status is irrelevant to the operation of the batteries in the grip.
12-28-2014, 06:18 AM   #12
I use Eneloops and have NEVER had a problem with the Battery Grip.
obin
12-28-2014, 06:38 AM   #13
I'm still trying to figure out why someone would want to use AA batteries in their grip for an extra 100-150 or so shots when they could pop another Li-90, or whatever the camera takes, in and be good for around 980 in addition to the cameras battery. if it's because of weight I find a heavier camera is easier for me to hold steadier.
12-28-2014, 08:11 AM   #14
Docrwm's Avatar
Because there are times when you RUN OUT of battery power but still need the camera. AAs allow you to pop into any convenience store on the planet (near enough) and be good to go for a little while longer. That can be long enough for your camera battery to gain sufficient charge.
12-28-2014, 08:41 AM   #15
Because AA batteries can be found everywhere in the world that reliable electrical power can not.
obin
batteries, battery, battery grip, camera, grip, mirror, pentax help, photography, steve, troubleshooting
Can K3 use two batteries at the same time? (Battery grip and inbody) enyceckk Pentax DSLR Discussion 4 11-09-2014 09:41 AM
For Sale - Sold: K20d + D-BG2 battery grip + 3 batteries Martin_Qc Sold Items 7 10-11-2014 05:19 AM
For Sale - Sold: K-5II (K5-2) body with extras: O-ME53 magnifier + battery grip + 3 batteries Quazimoto Sold Items 3 11-02-2013 02:25 PM
Price For K10D + battery Grip + 3 batteries Mapleleaf-Mick Pentax Price Watch 2 06-27-2011 03:43 PM
All times are GMT -7. The time now is 03:12 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
