12-03-2014, 05:15 PM   #1
K-3, auto focus problem
I had been using the DA300 f4 with my new 1.4 converter, when focus stopped working in following modes, Av, TAv, Tv and Sv.
Focus still works in P, U1 set to Av exposure mode, U2 set to TAv exposure mode and U3 set to P exposure mode.
To trouble shoot, I re installed the latest software, with no change, reset Custom functions, tried other lenses, still no joy.
The camera is well within warranty, so I assume it has to go back. I regret to send it off right now, will miss it during the xmas season.
Any suggestions, or have others had the same problem.
thanks, Ladybug36
12-03-2014, 05:25 PM   #2
jatrax's Avatar
Does the focus work without the TC?
Does the focus work correctly with other lenses?
Can you try the lens with another body?
Does the focus work with the TC and a different lens?
I've no ideas for you but the above might help with troubleshooting.
12-03-2014, 05:36 PM   #3
no, don't work without the TC.
focus don't work with other lenses.
I don't have another body.
the focus don't work with the TC on other lenses.
but as I mentioned in the post, it works in P, U1, U2 and U3
sent the same inquiry to Pentax.
12-03-2014, 05:43 PM   #4
crewl1's Avatar
Have not had this problem - does it focus in live view in other modes?
Are you having issues with SDM not working only or are the other lenses screw drive lenses and they also do not AF?
12-03-2014, 06:05 PM   #5
QuoteOriginally posted by crewl1 Quote
Does not focus in live view
12-03-2014, 06:20 PM   #6
jatrax's Avatar
QuoteOriginally posted by ladybug36 Quote
What focus mode are you in? Should say on the LCD screen right above the number of image left on card indicator.
You might also check the AF/MF switch, and flip it back and forth a couple times. it is possible it got stuck part way between.
12-03-2014, 06:26 PM   #7
I have had intermittent focus with the 1.4 TC. In every case, it started working after cleaning both the TC and camera body contacts.
12-03-2014, 07:29 PM   #8
tried AFA, AFC and AFS, no change, and since its a problem with other lenses the AF/MF switch only comes into play with the DA300.
Have cleaned the contacts, no change on the DA300 or with the 18-135mm lens I am using.
The latest, thought of using the AF button, and it now will focus in all modes, still nothing with the shutter button, at least I can use the camera, and won't send it for repair this year
12-05-2014, 03:57 PM   #9
Just to let You know, focus is now working with half way press, the Button Customization, AF Button, was set to AF2, when reset to AF1, it worked as designed.
thanks for the help, hope this will help others, that might have focus problems.
12-05-2014, 07:31 PM   #10
Well, that would do it!
Thanks for closing the loop!
auto, av, exposure, focus, focus *only, mode, tav
Catch in Focus K-3 problem TCerbo Troubleshooting and Beginner Help 22 12-18-2014 02:28 PM
Focus problem with the K-3 lezama Troubleshooting and Beginner Help 7 12-12-2014 11:59 PM
K-3 auto focus problem DAKS Pentax K-3 23 11-11-2014 03:03 AM
Tamron 70-200 auto focus faster with k-3 or k-5 IIs ? skid2964 Pentax DSLR Discussion 11 01-25-2014 12:27 AM
K-3 vs E-M1 auto focus lijimmy80 Pentax K-3 4 11-13-2013 03:13 PM
All times are GMT -7. The time now is 12:02 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
