Originally posted by ChristianRock Metering can be set to spot, center-weighted or matrix.
Not with lenses lacking the A contacts. For those matrix in unavailable.
---------- Post added 12-04-14 at 01:06 PM ----------
Originally posted by roosm Could the ISO settings be different between "m" mode and "user" mode making one picture appear brighter on the LCD than the other simply because it was another ISO-setting?
In a word...yes.
Stop-down (green button) metering on the K-5 (and most other Pentax dSLR) uses a different set of exposure algorithms than open-aperture metering on the same camera with lenses having the A contacts. The two systems often indicate different exposure values (EV) for the same scene, though they are usually within a stop of each other. If the difference is greater, there are two common causes:
- The camera is in spot meter mode with the center metering area pointed at something lighter than the rest of the frame
- There amount of light reaching the light sensors is below the linear range for the meter.
The second point is fairly likely, can happen in moderately dim light, at moderate apertures, at ANY ISO, and is difficult to explain. The short explanation is that stopping down the lens (green button) decreases the amount of light available to the meter and if that falls below -3 EV, the meter will indicate higher shutter speed than is appropriate.
