12-05-2014, 09:40 AM   #1
How do I use the timer or remote with the high frame rate on my K-50, pleases
It looks like those options are exclusive from each other if I use the main four way controller.
Is there a way to combine the 6fps mode with the remote or timer?
Thanks.
12-05-2014, 10:04 AM   #2
It is pretty easy and straight forward. Here is a link to the manual. You can save it to your desktop for quick reference. Now you can search it just like any other document.On page 123, you want to set continuous shooting by using the up arrow on the 4 way controller to select the continuous shooting icon, beneath it you have a hi or lo option (6 or 3 fps).
Then attach your remote shutter. Then depress the shutter and the camera body starts taking images at the selected rate until 1) you release the shutter or 2) the buffer fills, then it will slow down to taking images at the rate (dependent on the speed of the card) that prior images are moved to the SD card.
Or, alternatively while not using a remote, the camera will take images continuously while the shutter is depressed.
12-05-2014, 11:54 AM   #3
QuoteOriginally posted by bladerunner6 Quote
Yes, use a remote to trigger the shutter. Depending on the remote, you may be able to program a delay, duration for the shutter burst, and/or a timed sequence.
12-06-2014, 11:10 AM   #4
Thanks for all your help everyone.
I have just the dirt cheap basic IR remote, so maybe I need to upgrade.
camera, frame rate, pentax help, photography, timer, troubleshooting
Focusing on Pentax K-Mount only - Or what should I do with my M42s antipattern Pentax SLR Lens Discussion 5 01-30-2013 10:26 AM
How Do I Read/Use The Numbers/Colors On My Sears 60-300mm Lens? TechGuru Pentax SLR Lens Discussion 5 12-07-2011 05:21 PM
How do I use external TTL flash on the *ist D? ducdao Pentax DSLR Discussion 11 09-01-2011 04:33 PM
How do i use this lens on my K-x?? Silverkarn Troubleshooting and Beginner Help 14 09-02-2010 12:41 AM
How do I use flash with M lenses on the *istD Ole Pentax DSLR and Camera Articles 9 05-16-2007 02:13 AM
All times are GMT -7. The time now is 01:41 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
