12-09-2014, 03:16 AM   #1
Shake Reduction icon turning off during shaking
Hello, I am a beginner and using the K-50 in automatic mode. I have the Shake Reduction mode turned on. When I look through the viewfinder, click halfway on the shutter, and then shake the camera a bit I see the SR icon going off in the view finder. If I stop shaking, or shake it instead much more gently than before, the icon comes back on. Is it normal that the icon is going off with more than a very very gentle shake?
In addition, I cannot hear anything different when the camera has SR turned on versus off when I shake, when using the K-50 with the viewfinder. In contrast, if I use the camera in Live Mode with the LCD monitor/screen, and I have SR manually turned on, I hear the sound of (what I think is SR engaging) as I shake the camera. (Note: The SR icon doesn't go off when I am using camera in Live Mode with the LCD screen/screen.) If I manually turn off SR, I do not hear that sound when in Live Mode. Thanks in advance for the help.
12-09-2014, 04:10 AM   #2
ramseybuckeye's Avatar
The shake reduction was designed to defeat shakes when you are trying to hold it still, slight shakes not tremors. When you intentionally shake it I would assume it would disengage if nothing else than to keep from being damaged.
12-09-2014, 05:32 AM   #3
The icon going out doesn't mean the SR system is disabled, only that it's not stabilized (it's recalculating to counter the different/stronger shake).
12-09-2014, 06:52 AM   #4
Fogel70's Avatar
QuoteOriginally posted by seattlemark Quote
The SR is only moving the sensor when the camera is capturing images/video, so when you use OVF the sensor is only in motion when the image is captured.
It's just no point in moving the sensor when the shutter is closed using OVF.
12-09-2014, 09:59 AM   #5
QuoteOriginally posted by Fogel70 Quote
When using Live View with the monitor/screen, is the sensor being used continually (which is why I am hearing the SR in that mode) ?
12-09-2014, 06:05 PM   #6
PeaceFroggy's Avatar
If I recall it correctly, yes
camera, icon, lcd, mode, pentax help, photography, reduction, shake, shake reduction, sound, sr, troubleshooting, viewfinder
Does Shake Reduction ever turn off automatically? stillshot2 Pentax K-30 & K-50 16 05-12-2014 01:40 PM
Shake reduction moving while SR off melander Troubleshooting and Beginner Help 6 11-25-2013 12:39 PM
Shake reduction during self-timer/MLU lhwb Troubleshooting and Beginner Help 8 10-01-2012 05:51 PM
Shake Reduction on or off? GoldenRGuy Pentax DSLR Discussion 7 02-16-2011 08:37 PM
Why Turn Shake Reduction Off? slowdive101 Pentax DSLR Discussion 36 02-14-2010 07:03 AM
All times are GMT -7. The time now is 04:56 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
