12-09-2014, 08:52 PM   #1
How to delete files on SD card
Hi there,
After the first time I downloaded pics to Lightroom I was then able to delete them in the file manager on my PC (using Windows 8.1). However, now I can't seem to delete the next several hundred photos. They've been downloaded to LR fine, but when I try to delete them, it says they're being deleted, but then when I go back to the parent file and click it, they're all still there. I've tried repeating, but it just does the same thing. Any ideas? Gotta figure this out or I won't be able to take more pics :-(
12-09-2014, 09:01 PM   #2
Oldbayrunner's Avatar
DO NOT Delete or format your SD card with your computer. Use your camera to delete or better yet use reformat in your tools menu. That will erase all the photos on your card.
12-09-2014, 09:02 PM   #3
sergysergy's Avatar
Yep, do it from the camera. Make sure they are not protected
12-09-2014, 09:07 PM   #4
RichG's Avatar
Had the same experience trying to delete files from the PC. The others are right. Do it from the camera and formatting is less likely to garble things than selectively deleting.
12-09-2014, 09:15 PM   #5
QuoteOriginally posted by TrailRunner Quote
Hi there,
Is your card write protected?
12-09-2014, 09:47 PM   #6
Otis Memorial Pentaxian
Once more, joining the chorus!
  • Use your camera's format function as the best way to do a bulk delete on a card
  • Don't use your computer operating system's format feature
  • If you do end up with a corrupted SD card (not recognized by your camera), use the formatting software from the SD Association: https://www.sdcard.org/downloads/formatter_4/
  • Again, don't use your computer operating system's format feature
12-09-2014, 09:55 PM   #7
abmj's Avatar
Echoing the above. Plus - spend a couple bucks and buy a spare SD card. They are cheap, take up no room and are good insurance against a card failure or loss. We should NEVER hear someone say they can't take more pictures because the card is full.
12-09-2014, 10:26 PM   #8
awesome, thanks all! wow, much easier :-)
12-09-2014, 10:55 PM   #9
hks_kansei's Avatar
Odd, I have always deleted excess photos from my SD card using my PC without a problem.
If I want to selectively delete a few files (or selectively keep a few) using the camera takes forever.
Granted, I always connect my camera to the PC using the Pentax cable, and I delete the files through Windows explorer. (I haven't taken the SD card out of my camera in at least 4 years)
12-09-2014, 11:16 PM   #10
old4570's Avatar
Yeah , same here ..
I don't read from the camera any longer , I just pull out the SD card and read it through a SD card reader and PC , then just do a fast format after a file transfer ( Copy Paste ) to my computer .
The only cards that seem to have issue , are the cheap no brand ones ..
Just avoid cheap no brand SD cards ...
12-10-2014, 12:48 AM   #11
I plug the USB cable into my camera and use Bridge to download and delete images from the camera. Been doing this for several years, not hit a problem yet. If I do I'll simply reformat the card in the camera, which is what I did when I first started using it.
12-10-2014, 05:13 AM   #12
Paul the Sunman's Avatar
There is a known problem (and solution) on some macbook pros with Sandisk SDHC cards. The computer sees the card as read-only, even when the card lock is in the off position. The solution is bizarre: set the lock slider half way between lock and unlock. If you get it just right (not too hard) it is writable again.
I frequently let Aperture delete my photos from the card after download, and it's never caused a problem.
12-11-2014, 09:49 AM   #13
bobell69's Avatar
Problem is that after you have deleted them, you need to empty the trash can on the computer desktop before you take out the card from the card reader
12-11-2014, 12:34 PM   #14
QuoteOriginally posted by bobell69 Quote
No! Not the case on any computer system I know of. However, you do require that no application is using the card when you try to "eject" it.
12-11-2014, 07:58 PM   #15
ramseybuckeye's Avatar
Another plus 1 for formatting the card in camera to delete photos. Formatting the card with the computer can cause problems.
camera, file, files on sd, pentax help, photography, pics, troubleshooting
How to put firmware update on SD card? New Englander Troubleshooting and Beginner Help 11 04-07-2018 09:11 AM
Number of raw files on sd card neostyles Canon, Nikon, Sony, and Other Camera Brands 2 09-29-2014 05:46 PM
HELP! Corrupted files on SD card catastrophe Pentax DSLR Discussion 24 11-22-2012 08:03 AM
Corrupted raw files on SD card Pablom Digital Processing, Software, and Printing 6 03-03-2012 03:34 PM
How to rescue photos on a corrupted SD card ve2vfd Accessory and Memory Articles 23 02-22-2009 06:30 AM
All times are GMT -7. The time now is 04:15 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
