Originally posted by clackers Sunshine, if you can set up the flashes so they can 'see' your camera's popup flash, they'll fire without further investment.
That is only true if the flash units the that OP chooses have a builtin optical slave trigger. Some flashes do, some don't. The OP didn't mention which flashes he/she is considering.
The cheapest way to sync the flashes would be with a cable, presuming the camera has a PC socket. If there is no PC socket, an adapter to sync off the hotshoe would be required.
Optical slaves are not terribly expensive, either.
Radio slaves are the most expensive, but also the most versatile.
If using a direct connection, via a cable, care must be taken that the trigger voltage on the flash is not too high for the camera to handle. A trigger voltage that is too high can fry the electronics in a modern camera. The trigger voltage should be no more than 15-20 volts. This is probably not a problem if using new flash units. However, many people like to go to eBay and buy classic flash units, such as the Vivitar 283, which can have trigger voltages of more than 200 volts.
