Originally posted by DavidSKAF3 Hi!
What is a color managed workflow that follows generally accepted conventions? Is it a way to skip calibration?
Thanks.
Dave
Originally posted by stevebrot No, calibration is the foundation.
What Steve said.
Accurate color management; i.e., a color managed workflow, incorporates several steps that insure accurate color rendition from capture to print. It involves using color charts, colorimeters, and spectrophotometers in order to calibrate cameras, monitors, and printers. Most people will only need a monitor with a built in LUT (Look Up Table) and a colorimeter to satisfy their needs. Unfortunately, those two items alone are north of about $500.00. Keep in mind that most people who will view your pictures online do not have calibrated monitors although I think most browsers are color managed these days. Still, if you have a properly calibrated monitor at the very least you'll know what you're putting out into the world is color accurate.
Here's a few links not for the faint of heart. It's a rabbit hole.
http://photo.net/learn/digital-photography-workflow/color-management/ * http://www.adobe.com/content/dam/Adobe/en/technology/pdfs/Why_Color_Management.pdf http://www.color.org/whycolormanagement.pdf http://www.xrite.com/documents/literature/en/L11-176_Guide_to_CM_en.pdf Canon DLC: Article Print: Understanding the Role of a Spectrophotometer in a Color Management Process ICC Frequently asked questions
---------- Post added 12-15-14 at 10:01 PM ----------
Originally posted by murrelet I just bought an X-Rite ColorMunki Smile. Any thoughts on this? I haven't opened the box and can return if the general consensus is that it's junk. I'm using LR4 and send my JPEGs to AdoromaPix for prints and photo books. I'm not using their color profiles since I figured that's useless without a calibrated monitor. Also starting to use Blurb for photo books. I'm noticing what I get back looks slightly underexposed or not as saturated as what I see on my monitor.
Read the links I posted above and you can decide for yourself if the Munki is enough for you.
I found the subject of color management fascinating when I was researching it and grew to believe it to be the foundation on which every color image should be built. It provides the basis for accurate color reproduction and a baseline from which to diverge in a purposeful manner. Lately I'm shooting mostly b&w film but I know when I shoot digital color I'm able to reproduce the captured colors accurately on my monitors and in prints (although I'm still using canned ICC profiles for my 3880 and various papers).
* "Buy the very best monitor you can afford. Scrimp on your computer upgrades, a new camera body or flashy accessories. Your monitor is the most important investment in your digital photography workflow. It is the foundation upon which all other elements in the workflow depend."
