Hi all,
I ran into an issue and wanted to see what's your regular practice about that.
I expected that, by setting the time in camera (the location and the time of both the "home" and the "travel" time) I would have pictures tagged with a date/time and an appropriate offset tag (e.g. UTC+2). Not the case.
Apparently the EXIF specification doesn't even contemplate a timezone tag, while the IPTC TimeCreated timestamp is set to xx:xx:xx +00:00, irrespective of what I did set in-camera.
Back at the home airport I reset the clock (didn't make much sense to chase the timezone changes mid-flight), and sure enough the pictures I took at the airport were mixed up with the others before (I was traveling westward).
Questions:
1. What the heck is the in-camera timezone setting for, if it doesn't do anything? only for "convenience"?
2. What do you do with respect to camera time settings and tagging when you frequently change timezones?
Thanks in advance
