12-22-2014, 10:33 AM   #1
Can't Access the eye-fi option in menu
Trying to get a ez share card to work on my K-500 and i cant access the eye-fi option in the menu. It shows that it is set to off, when i try to scroll down to it it does'nt scroll all the way to the eye-fi selection, the ability to scroll stops at the option above it. What am i doing wrong?
12-22-2014, 10:49 AM   #2
The reason you can't get to that option is that it is an option dedicated for the eye-fi card.
Your going to have to set the card up you have differently as long as it's compatible with your camera you will have no problem.
12-22-2014, 11:12 AM   #3
Thanks....that explains it...So I guess I need the eye-fi brand card, cause I'm getting no where with this ez share card.
12-22-2014, 03:34 PM   #4
The ez share card should work the same as any other camera-agnostic wifi sd card - put it in the camera (which will power it), download the ez share app to your device of choice, search for the card in the wireless section of your device, select it, then view whatever shots you save to it using the afore mentioned app, etc.
I use a Toshiba FlashAir card. Works well in a variety of cameras.
access, access the eye-fi, camera, eye-fi, eye-fi option, menu, option, pentax help, photography, scroll, troubleshooting
Can't turn the camera power on while pressing the MENU button PParent418 Troubleshooting and Beginner Help 2 08-28-2014 09:46 PM
Error Message:'No eye-Fi card inserted in SD2 slot' wizofoz Pentax K-3 40 04-30-2014 06:17 PM
eye-fi / sandisk eye-fi sd card with Q thehetfield Pentax Q 5 11-16-2012 04:08 AM
No Access to C MENU in K-7 violini Troubleshooting and Beginner Help 11 08-18-2011 10:58 AM
Debug menu access for the K100DS? Nachodog Pentax DSLR Discussion 3 04-14-2010 02:27 PM
All times are GMT -7. The time now is 03:11 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
