Originally posted by old4570 M42 adapters for K mount ..
There are two I know off , Chinese and the Pentax made one ..
Probably many manufacturers of the cheap ones -- it seems to be a crap shoot how good they are, even if you get them from the same supplier after some time has passed. (I've had ones where the threads were off and the lenses all mounted upside down when screwed-in.)
Quote: I always thought they were designed to go into the body , and so convert the body to M42 , rather than convert a lens from M42 to K mount .
Yes, they are designed to stay in the body, thus the spring clip.
Quote: The Pentax one is so much nicer than the Chinese version ..
...and if you are going to use it in the body, get the Pentax one. Anyone who has more than a couple m42s should have at least one genuine Pentax version, and will probably end up with many cheap ones (plus at least one non-infinity one, which also come in handy).
Quote: Certainly remove the spring clip and notch the adapter if converting a lens rather than a body ..
The cheap ones basically don't work in the body unless you only use m42 lenses -- if you don't remove the spring clip and put it in there, you WILL be spending the afternoon trying to the remove the damn thing from your camera. So the cheap ones are really only good for attaching to the lens as far as I'm concerned. The notch would have to go on the lens itself (right?) not the adapter, so it is a permanent and technically damaging alteration of the lens...
