12-27-2014, 09:02 AM   #1
k3 dark iso
Recently bought the k3..here's my issue. When shooting outdoors in great sunlight with 35 mm lens at 125/2.4 I still have to bump up the iso to at least 600 to get a evenly balanced shot..this doesn't seem right to me..I mainly do natural light photography and with my other brand I used a 28-70 2.8 L at 250/ 2.8 I never had to go above 200iso. Any ideas or help would be greatly appreciated. .thanks in advance
12-27-2014, 09:08 AM   #2
aleonx3's Avatar
QuoteOriginally posted by jnast78 Quote
What metering mode are you using?
12-27-2014, 09:14 AM   #3
QuoteOriginally posted by aleonx3 Quote
I've tried it with all 3
12-27-2014, 09:26 AM   #4
jatrax's Avatar
All metering modes produce the same result in a fixed test?
Check the exposure compensation.
Do you have another lens to test with to eliminate a lens problem?
What shooting mode are you using? M, Av, Tv?
12-27-2014, 09:28 AM   #5
Thanks aleonx3 ,
My main concern is once I switch to the Tamron 70-200 my shutter speed is going to make me bump up the iso so much that the pics won't be usable. I've watched every video I could find and read the manual a few times. .possibly a defective product???
12-27-2014, 09:30 AM   #6
Yes all produce the same result.
I have tested it with 2 other lenses
I'm shooting in manual
12-27-2014, 09:32 AM   #7
aleonx3's Avatar
Do you have a photo with EXIF data to show what is going on?
---------- Post added 12-27-2014 at 11:34 AM ----------
If you are shooting in manual mode, try to hit the green button to see if the shutter speed will change...
12-27-2014, 09:35 AM   #8
jatrax's Avatar
Very strange that spot metering produces the same exact result as matrix, this is almost never the case unless you are shooting a featureless white wall.
Ok, and does it work correctly with the other 2 lenses or do you get the same result?
And did you check the exposure comp?
12-27-2014, 09:47 AM   #9
powasky's Avatar
Most important thing you can do to help us help you is post a picture with full exif. From that we can probably determine what is going on.
12-27-2014, 09:51 AM   #10
As a test the exposure compensation I put the camera on a tripod outside lemon tree as subject in semi shade side lit from the sun. Took pics from -5 to +5 in manual 125/2.4 iso 400 and no difference at all
12-27-2014, 10:14 AM   #11
Banned
Just a shot in the dark here, but are these manual lenses? If so, is "Using Aperture Ring" enabled and / or aperture ring set to "A"?
12-27-2014, 10:27 AM   #12
ND filter?
12-27-2014, 10:37 AM   #13
No ND and not manual ..
I'm stumped.. I've been shooting with canon for about 6 years I'd say I have a more than fair amount of experience ..cant figure this one out ..might just be the camera..only one way to find out
12-27-2014, 10:39 AM   #14
aleonx3's Avatar
Obviously, it could be a faulty camera.....
12-27-2014, 10:39 AM   #15
Flugelbinder's Avatar
...If you are shooting in manual mode, try to hit the green button to see if the shutter speed will change...
Sorry for the ignorance, but what would this show/prove?
camera, exif data, iso, pentax help, photography, troubleshooting
Night Dark Gotham (K3 Contest Rd2) ILLmatic173 Pentax K-3 Photo Contest 10 08-10-2014 12:47 AM
Black & White K3 Contest Round 2: Dark Places K McCall Pentax K-3 Photo Contest 13 07-21-2014 05:45 AM
K3 vs K5 high ISO noise. normhead Pentax K-3 & K-3 II 112 03-04-2014 03:57 PM
K3 iso 8000 DDoram Pentax K-3 & K-3 II 10 01-20-2014 09:50 AM
New K3 vs K5ii high iso RAW tests ihasa Pentax K-3 & K-3 II 8 11-04-2013 09:15 AM
All times are GMT -7. The time now is 05:39 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
