01-27-2015, 05:08 AM   #16
patrick9's Avatar
QuoteOriginally posted by tezza Quote
in Menu just toggle enable/disable aperture ring when swapping lens & that works & for the age of the lens & the No. of times I use it...quite happy. Thanks for suggestions which were all around it. Much appreciated
That is the first thing I do when I get a new Pentax. Once you set it to enable aperture ring, just leave it there. No need to change it back and forth when changing lenses. Having it set there has no effect on lenses with out Aperture rings. It just lets the camera work if you choose to be off A or using M lenses
aperture, bottom, camera, contacts, k50, lens, matter, menu, moment, pentax, pentax help, photography, post, press, screen, shutter, thanks, troubleshooting
Some walkshots of Pentax Q7 with 02 zoom lens at Shanghai jim7592 Pentax Q 13 07-27-2013 07:16 PM
Shutter won't fire anselesn Troubleshooting and Beginner Help 5 07-20-2013 04:30 PM
35mm Flektogon f/2.4 Carl Zeiss - Lens Won't Focus at Infinity bigrex Troubleshooting and Beginner Help 2 03-07-2013 09:52 PM
K2000 Shutter Won't Work With Lens Attached BernieH Troubleshooting and Beginner Help 6 08-01-2012 01:18 PM
K-7 video with unwanted info on top and bottom des2hand Video and Pentax HDSLRs 4 03-31-2010 05:28 AM
All times are GMT -7. The time now is 11:49 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
