01-01-2015, 10:00 AM   #1
K-50: Can't Enable Shake Refuction
I have a K-50 with an M42 lens screwed and I can't enable shake reduction in any mode. I can see the option in the menu but it's greyed out and can be selected.
Anyone know how to get this enabled? I thought the benefit of this body was that shake reduction is done in the body, not the lens.
01-01-2015, 10:06 AM   #2
mattt's Avatar
What drive mode are you in? if it is 2s delay, remote release, HDR, etc it will not be available...
01-01-2015, 10:10 AM   #3
UncleVanya's Avatar
I have had it not prompt for the focal length and restarting it has helped.
01-01-2015, 10:16 AM   #4
I'm in M, TAv, Av, and Tv. Not 2s delay or HDR.
It's a manual fixed lens if that matters.
01-01-2015, 10:16 AM   #5
dakight's Avatar
QuoteOriginally posted by pentexas Quote
What shooting mode is set? There are a number of things which if selected will disable SR but as far as I can remember none of them are related to the lens. If the 2 second timer, 12 second timer or Remote Control shooting modes are enabled then SR is disabled. There may be other settings as well but I don't recall them.
01-01-2015, 01:30 PM   #6
Oldbayrunner's Avatar
You need to go into your record menu, E dial programming and for M change it from Pline to TVshift.
01-02-2015, 07:53 AM   #7
I did that, no go.
01-02-2015, 08:03 AM   #8
UncleVanya's Avatar
Have you shut it off and removed the battery and restarted? Set all menu items to default etc?
01-02-2015, 08:38 AM - 1 Like   #9
Just figured it out!
I changed "Using Aperture Ring" from 1 to 2 (shutter will release when aperture ring is not set to the "A" position").
Now shake reduction is available.
body, camera, k-50, lens, pentax help, photography, reduction, troubleshooting
Sigma can't repair my 50 F2.8 macro as it is discontinued - who can? JinDesu Pentax SLR Lens Discussion 12 08-24-2013 12:23 PM
HELP! New Sigma 17-50 can't autofocus?!? rzarector Pentax SLR Lens Discussion 27 06-27-2013 09:58 AM
shake reduction can't turn on ? davidsyd Pentax K-30 & K-50 3 12-24-2012 07:32 AM
Can't turn shake reduction back on - K5 vrphoto Troubleshooting and Beginner Help 5 04-10-2011 09:22 PM
[k-x]How to enable shake reduction in video mode with manual lens? tiny Pentax DSLR Discussion 9 03-15-2010 07:56 PM
All times are GMT -7. The time now is 01:43 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
