05-03-2015, 12:13 AM   #16
K57XR's Avatar
QuoteOriginally posted by CameraObscura Quote
Tried all possibilities: door open; door closed; with card; without card. Normally, when I insert a SD card, the card access light blinks momentarily, even if the camera is turned off. Now when I insert the card, nothing happens.
From your description above it seems there is no power going into the camera. If I'm not mistaken even a camera with toasted firmware will still flash the access light when a card is inserted as long as there is power. Have you checked the three battery contacts inside the compartment, in case one or more is somehow stuck recessed?
Not sure it will help but it's worth a try?
1) Make sure the power switch is off
2) Push a fully charged battery in as far as it will go and hold it there
3)Turn the camera on while holding/pressing the battery in at the same time.
Good luck.
05-03-2015, 04:56 AM   #17
there is a little switch under the sdcard door, push it down andI will bet you it will fire up. Inspect it carefully you will find it. I won a k-30 off Ebay brand new not one actuation because they at Roberts camera could get it to turn on. I put it in debug mode via the thread and viola. the only drawback was it would record shots slower than 200th of a second So I didn't give up after carefully playing around I discovered that the sdcard door was not pushing the switch down far enough ,once I solved this I have a NEW CAMERA. I will put my money on it , that this is your problem. report back
05-24-2015, 12:48 PM   #18
I agree that it sounds like a power problem. However, the battery contacts are good and clean.
I also tried the little switch under the SD card door. No go.
---------- Post added 05-24-15 at 02:25 PM ----------
I finally gave up and listed it on eBay for parts/repair. If it seems easy to fix and someone wants to have a go at it, now is your chance.
05-24-2015, 02:33 PM   #19
set your sd card for debug
05-24-2015, 03:02 PM   #20
No luck. Copied the MODSET.492 file to the root of the SD card, placed the card in the camera, and held the AV +/- button while turning on the camera. No sign of life.
05-24-2015, 03:29 PM   #21
try no sd card , first with the door open then with it closed
---------- Post added 05-24-15 at 06:32 PM ----------
also work that sdcard door switch out , in otherword use a q-tip and pump it in and out for a long time and vigorously . then try
05-24-2015, 05:09 PM   #22
Tried with the SD card door open, then with the card door closed.
Worked the card door switch for some minutes, removed and replaced the battery and tried again, with the door open and closed.
Still no sign of life.
05-24-2015, 05:16 PM   #23
guess its over and out
05-24-2015, 05:24 PM   #24
Unfortunately, it seems so. I hadn't used it much but it took some good pictures when I did.
Thanks to all who responded here.
camera, cameras, card, door, k-01, page, pentax help, photography, price, refurb, repair, repairs, ricoh, sd, sd card, troubleshooting, website
K30 will not turn on theoicarry Troubleshooting and Beginner Help 4 08-29-2014 04:16 PM
K-01 with Tamron 70-200 will not nail focus treebeard Pentax K-01 8 03-22-2013 05:46 AM
Help! Pentax K-r won't turn on? Marie Anette Pentax K-r 9 02-10-2013 04:08 PM
K-5 will not turn on - Pentax Support advice carrrlangas Troubleshooting and Beginner Help 2 01-10-2013 11:02 AM
K-m DSLR Will Not Turn On Robbie28 Troubleshooting and Beginner Help 7 02-26-2011 09:22 AM
All times are GMT -7. The time now is 06:09 PM. | See also: NikonForums.com, part of our network of photo forums!
