Originally posted by dcshooter but extension tubes for macrophotography are exactly the opposite - a classic highly lit scenario where the minimal difference in reflectivity between the paint and the flocking will least matter, since the obvious problems sought to be avoided are caused by the specularity of the light rather than its intensity.
Hi DC, I have nearly used up the Krylon matt black, so next time I will try the Rustoleum spray paint you mention.
Here is a test of the bore of a macro tube I made for the 4x5 Speed Graphic.
The bore was originally painted with the Krylon Matt Black spray.
I stuck a little rectangle of flock in the bore to compare the low angle specular reflection of the two surfaces.
Photographed using the Pentax - m macro f/4 100mm at iso 400, f/32 and 1/15th
Results:
The source, CFL lamp is almost RGB 255,255,255 in the bright spots
The reflection off the Paint: RGB 255,157,74
The reflection off the Flock: 16,7,4
