01-09-2015, 02:59 PM   #16
emalvick's Avatar
QuoteOriginally posted by trishytee Quote
Well whatever it is doing what is the solution. Plus why do that if I take the photo in daylight, being no noise problem??
The camera doesn't know you're shooting in daylight. It just takes the black shot because it assumes you will have a noisy shot.
It sounds like there might be a glitch in the firmware because if you have the High ISO noise off, it should solve your problem. Perhaps try resetting your phone to defaults and then adjust the settings again? I'm not sure if you can, but perhaps you can reinstall the firmware. I'm not sure if our cameras are smart enough to stop you from reloading the firmware you already have on your camera or if they'll reject it straight up.
01-09-2015, 03:09 PM   #17
clackers's Avatar
QuoteOriginally posted by emalvick Quote
Dark Frame Subtraction and High ISO Noise handling do different things.
01-10-2015, 10:35 PM   #18
trishytee's Avatar
QuoteOriginally posted by BrianR Quote
I don't have a k-7, but it looks like the dark frame subtraction can't be turned off for exposures longer than 30 seconds. There are a few threads about it https://www.pentaxforums.com/forums/6-pentax-dslr-discussion/66277-k7-long-exposures.html. It can be completely disabled on the k5 series, I'd guess on the k3 as well but double check on that if you're going for an upgrade.
You could take multiple 30 second exposures and stack later in post processing.
Thanks, Brian, yes I am thinking of upgrading, but really will rethink this, as it is a pain in the derriere missing out on shots. I guess the second K7 idea is not too bad, but I don't have the lenses to do that.
01-11-2015, 12:18 AM   #19
clackers's Avatar
It just needs one lens that's not on your other K7, Trishy!
At f8, the kit lens will be sharp enough! :-)
01-11-2015, 08:10 AM   #20
I'm worried I wasn't clear- you can completely turn off Dark Frame Subtraction on the k5 series (I've verified with my k5iis), meaning a 100 second exposure is finished and ready to go after a grand total of 100 seconds (plus a fraction of a second thinking time). There's no extra waiting, and it would work fine for what you're doing.
Your k7 is frustrating you for this application, a second would be an awkward workaround imo.
Look at the lower tier cameras if a used k5 is out of reach. The manuals of the k30/50 seem to indicate Dark Frame Subtraction can be turned off completely for them as well (or Slow Shutter Speed NR as Pentax calls it), but I'd also verify this is the case with someone who owns one. Some older models may also be ok for you (it can be turned off on the now dirt cheap k100d), the k20 and k7 unfortunately suffer from stupidity of design here.
01-14-2015, 07:30 AM   #21
Oldbayrunner's Avatar
Afaik, the only way dark frame subtraction can be turned off on the K7 is using debug mode. You can look it up and find out how if you want but personally I don't like messing with my cameras software and would rather upgrade to something newer that will do what I want.
bulb, daylight, image, instant, light, nr, photography, shutter, time
Anyone worked out the write speed yet? DogLover Pentax K-3 9 11-05-2013 08:01 AM
645D write speed jackinkc Pentax Medium Format 28 08-01-2012 03:39 AM
K200D Write Speed Biro Pentax DSLR Discussion 4 01-09-2009 04:47 AM
k10d read/write speed? silent_eyes Pentax Camera and Field Accessories 3 09-20-2008 04:03 PM
SDHC write speed cautious Photographic Technique 3 09-16-2007 02:41 PM
All times are GMT -7. The time now is 07:46 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
