01-14-2015, 11:08 AM   #16
UncleVanya's Avatar
Preflash isn't typically visible.
01-14-2015, 11:17 AM   #17
Master of the obvious
savoche's Avatar
QuoteOriginally posted by el baroda Quote
I tried the 2-second set up as you suggested and saw 2 very distinct flashes of about the same intensity. The first looks like the "red eye reduction" flash.
Any comment?
That's your pre-flash. The intensity of the "real" flash might be weak or strong, depending on what exposure the camera needs.
01-15-2015, 06:25 AM   #18
Any comment?
Switch red-eye reduction off and try again. If I switch the red-eye reduction off, I get one flash before the mirror goes up and one when the picture is taken. Tested on K100D + AF540FGZ.
01-16-2015, 11:53 PM   #19
As I said before, it is usually quite visible in the optical viewfinder. The main flash isn't at all, as then the mirror is up.
So, if you see flashing through the viewfinder, it is the pre-flash (and/or the redeye reduction, in case it is switched on).
Of course, this does not work with the K-01.
Using the 2 sec delay for the flash test doesn't make much sense to me, except that it may make it easier for you to concentrate on what's happening.
01-17-2015, 08:41 AM   #20
UncleVanya's Avatar
QuoteOriginally posted by RKKS08 Quote
I have to admit that I haven't paid attention to the optical viewfinder in that way so I will test it. I haven't noticed it, and most reports on this type of flash indicate that the pre-flash is hard to see for most but some people react to it and can see it.
The 2 second delay can be used to allow you to not look through the viewfinder and casually see the preflash is working.
01-21-2015, 01:54 PM   #21
Thank you all for your input. With due respect to everyone, I am still very confused because of the conflicting material I have read here and elsewhere. Many claim that the "pre-flash" is not visible to the naked eye, while some claim the opposite. The important thing is I have found that both my built in and external flash are working well. Kind regards to all.
01-21-2015, 01:58 PM   #22
It is visible, it is just hard to separate from the main flash unless you do some of the above things mentioned (look through the viewfinder to see it, use 2-second delay, etc)...
01-21-2015, 03:35 PM   #23
UncleVanya's Avatar
Human reaction times are not fixed - people have different levels of calibration if you will. Some will see it and blink. Most will not. Some see it via aids like looking through the viewfinder which differentiates it so they know they saw it prior to the main flash which doesn't fire until the mirror is up. Does that help?
01-22-2015, 01:42 PM   #24
I looked through the viewfinder and saw the "pre-flash". Thanks.
---------- Post added 01-23-2015 at 07:43 AM ----------
Yes, it does help. Thanks.
camera, cameras, flash, k5, k5 and k7, k7, night, p-ttl, pentax, pentax help, pentax k5, photography, thanks, troubleshooting, viewfinder
HELP!! 645nii and fa75 Aperture "A" doesn't work CrazyGenius Pentax Medium Format 5 10-17-2014 08:07 AM
Optical differences between Pentax "K", "M", and "A" lenses 6BQ5 Pentax SLR Lens Discussion 31 01-10-2014 01:02 PM
Don't say Pentax "Q" in French ... "Q" = "cul" = "A--" Jean Poitiers Pentax Q 52 11-10-2013 06:25 AM
I Don't "Need" Another Lens... tabl10s Pentax SLR Lens Discussion 21 04-23-2013 01:24 PM
DA* SDM lens overexposure on a K5 - The moral is "don't panic." Delgado Pentax K-5 & K-5 II 7 12-26-2010 05:19 PM
All times are GMT -7. The time now is 07:23 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
