01-12-2015, 04:08 PM   #1
adriano perticone's Avatar
Mirror stuck problem in K-50 posible solution
I find a posible solution at the mirror stuck problem. In my case i have the problem only with the kit lens. While taking a picture the mirror would go up to capture the image, would return partially and get stuck midway. The camera was trying to align the mirror to its correct position but was failing again and again and eventually it hanged. I tried to power it off and even that would not happen. The only option left was to remove the battery.
With my other lenses, i never have a problem. I have a Sigma 28-105 DG, a Pentax 80-320, a tokina 19-35, a takumar 50 and a smc 35-80. The solution (untill now) was cover one contact with a piece of adhesive tape. In mi case, i never have again the problem.
NIKON D810  Photo
01-12-2015, 04:54 PM   #2
UncleVanya's Avatar
Does anyone know what that contact does?
01-12-2015, 04:55 PM   #3
Interesting. Thanks for sharing.
What is the contact for? I noticed only some DA/DAL lenses have it, while FA lenses don't. Do you notice any issue focusing or metering or camera recording lens information after blocking this contact?
01-12-2015, 04:57 PM - 1 Like   #4
It is the ground on lenses with plastic mounts.
With metal mounts the whole mount is the ground.
01-12-2015, 05:08 PM   #5
QuoteOriginally posted by cyclone3d Quote
So it looks it is fine to block it?
01-12-2015, 05:09 PM   #6
works ok blocked.
01-12-2015, 06:45 PM   #7
interesting. how did you reach that conclusion? was it the only lens with the aforesaid contact?
01-12-2015, 11:51 PM - 1 Like   #8
Lowell Goudge's Avatar
The contact is , as others have said, the ground for the lens on plastic mount lenses.
Metal mount lenses do not need this because the whole lens mount is conducting.
It is interesting, because I would expect that masking this contact could lead to failure of the lens to be identified or communicate properly. You say masking it made everything better, but in liking at the contact it seems very dirty. Perhaps cleaning it is required. Maybe the intermittent nature of the contact is the issue not it being present.
If this were the case, every metal mount lens would exhibit the problem as well, and I am sure theybdont
01-13-2015, 01:18 AM   #9
Yep. I say either the ground point on that mount or the bayonet on the camera itself it too dirty to get good contact.
Clean it up and it should work just fine.
"Masking", quite literally, the problem is not a correct fix.
01-13-2015, 06:26 AM   #10
There is the possibility that the kit lens was not manuf'd properly. The only way to test this would be to try with another plastic mount DA/DAL lens.
camera, mirror, pentax help, photography, solution, troubleshooting
Mirror stuck problem in new Pentax K-50 gurpreet_cpq Pentax K-30 & K-50 46 06-08-2016 10:19 AM
Mirror stuck problem with Pentax K-7 Hans-Christian K Troubleshooting and Beginner Help 6 04-03-2014 04:32 PM
K-30: Mirror Slap Sound Solution? Elley Troubleshooting and Beginner Help 8 04-28-2013 06:18 PM
645 mirror stuck in up position gawan Pentax Medium Format 3 11-21-2011 03:38 PM
MX Problem - Mirror Stuck Leslie P Pentax Film SLR Discussion 3 11-04-2007 02:28 PM
All times are GMT -7. The time now is 11:08 AM. | See also: NikonForums.com, part of our network of photo forums!
