01-24-2015, 11:10 AM   #1
k20d diopeter adjustment lever
Does anyone know where I can get a replacement k20d diopeter adjustment lever ?
01-24-2015, 03:35 PM   #2
Try contacting the Pentax authorised repairer in the USA or Canada. It's a screw fastened part, so there 's probably a seal or O-ring behind it that might need replacing too once you take it off (being an old body, the seals can start to stick to the mating faces and fracture when opened up.) When you make the call, ask them about it to make sure you don't need to remove the whole top to remove it.
01-28-2015, 04:58 PM   #3
Reffering to an old post
<<Part arrived, fitted in approx 30 seconds.>>
Well pleased.
01-31-2015, 10:48 PM   #4
QuoteOriginally posted by hsherd Quote
So i don't think it is a screw fastened part
I have a K20D top from an old repair and I can't see how you can replace the lever without lifting the casing top off. I'll be happy to be wrong on this one, so let us know how you go.
adjustment, camera, diopeter, k20d, lever, pentax help, photography, troubleshooting
K-7 Diopter Adjustment lever Mike.P Troubleshooting and Beginner Help 12 01-23-2015 04:25 PM
AF adjustment (K20D) WMBP Pentax DSLR Discussion 12 05-25-2009 03:58 AM
K20D AF adjustment TTQ225 Pentax SLR Lens Discussion 4 05-09-2009 12:05 AM
diopeter/viewfinder quesion solaris Pentax DSLR Discussion 9 01-26-2009 01:41 PM
K20D AF adjustment ? Confused Pentax DSLR Discussion 5 01-25-2008 11:22 PM
All times are GMT -7. The time now is 11:26 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
