01-24-2015, 11:33 AM   #1
Confused about sizing for lens caps and filters
I recently bought a K50 and noticed that the lens cap for the 18-55 lens didn't fit the 50-200 lens and vice versa. Neither do the filters I bought fit the zoom lens although they do fit the 18-55 . I have now lost the lens cap for the zoom and have no idea how to order the right size that will fit. Help!
01-24-2015, 11:39 AM   #2
GrimWolf's Avatar
The 50-200 and 18-55 are the focus ranges/distance on the lenses. If you look on the front on your lenses, you will see something like 52mm etc. this is the size needed for your lens caps/filters.
01-24-2015, 11:39 AM   #3
MadMathMind's Avatar
On the front rim of the lens, there's a little circle with a slash through it and a number next to it. That is the filter diameter. That's the size you need to buy.
It may also be elsewhere too.
See the bottom of the lens, where it says "17-70mm 1:2.8-4 DC [symbol] 72." That symbol is what you want to find. For this lens, the filter diameter is 72mm.
01-24-2015, 11:47 AM   #4
sterretje's Avatar
https://www.pentaxforums.com/lensreviews/SMC-Pentax-DA-Zoom-Lenses-c43.html pick the lenses and check the specs (you will be looking for the filter diameter specification).
Assuming you have the WR lenses. the diameter is 52 mm for the 18-55 and 49mm for the 50-200. I have the 18-55 WR and the number is also printed on the front of the lens; the 50-200 will probably also have it.
QuoteOriginally posted by Tish99 Quote
By the way, both lenses are zoom lenses, so you have lost the lens cap for both ??
01-24-2015, 12:01 PM   #5
QuoteOriginally posted by sterretje Quote
Thanks folks - really helpful.. It is just the 50-200 lens cap I have lost. I now know to buy a 49mm replacement. Sooooo much to learn!
---------- Post added 01-24-15 at 12:01 PM ----------
QuoteOriginally posted by GrimWolf Quote
Thank you - all clear now
---------- Post added 01-24-15 at 12:04 PM ----------
QuoteOriginally posted by MadMathMind Quote
The 40-200 lens didn't have it written on the outside (although the 18-55 did) but it was written on the inside. I think I need to buy a few spares for each.
01-24-2015, 12:17 PM - 1 Like   #6
Senior Moderator
Parallax's Avatar
I decided many years ago that the best way to avoid losing lens caps is to never, ever, EVER set them down anywhere. When you take it off of the lens, put it in your pocket. If you take it out of your pocket, put it on the lens.
01-24-2015, 12:23 PM   #7
tvdtvdtvd's Avatar
QuoteOriginally posted by Parallax Quote
Exactly the same thing I do. Always to the pocket, never, ever to the table, countertop, etc. To the camera
bag is a good alternate if handy.
Those lens leashes can seem tempting but in my experience they're far more annoying than useful.
01-24-2015, 12:27 PM   #8
+1 - If it's in your pocket the worst you can do is sit on it!
Phil
01-24-2015, 12:56 PM   #9
Not to change the subject, but a few other lessons I learned are:
Close the zippers on your bag even if you are planning on using it 5 minutes later. Nothing worse then forgetting and picking the bag up later and watching something fall out.
Close your memory card door. Same reason. You forget it's open and almost break it off putting your camera in the bag.
01-24-2015, 01:13 PM   #10
Banned
On a different note.... about filters, unless you want them for protection, get just one for the largest diameter lens you have, then get step up/down rings to fit the smaller lenses. Far cheaper!
01-24-2015, 01:15 PM   #11
Sandy Hancock's Avatar
QuoteOriginally posted by Mistlefoot Quote
Why would you put your camera in a bag if it has no memory card in it?
I always leave the door open until the card goes back in. Same applies when the battery is charging. There is nothing worse than going off for a day's shooting and either of those items are missing.
01-24-2015, 06:42 PM   #12
SpecialK's Avatar
I always shoot a shot before I leave.
01-24-2015, 06:46 PM   #13
Same here. Just a quick check to make sure everything is working.
01-24-2015, 08:05 PM   #14
The same reason one would lose their lens cap.
You can leave your lens cap open 1000 times with no problems, but just once do something silly and regret it. And I have several cards in my bag and as well as back up batteries. So it's normal for me to go out shooting with a battery in the charger and a memory card sitting on my monitor.
01-25-2015, 12:06 AM   #15
GrimWolf's Avatar
That's very true. I was going to go out shooting sat morning, and found I'd left my camera on standby when I last put it away, so the battery was flat. After charging it was all a bit too late. Spare batteries are now on my purchase list.
49mm, camera, cap, diameter, filter, filters, front, lens, lens caps, lenses, pentax help, photography, pm, size, symbol, troubleshooting, wr, zoom lens cap size
Dazed and confused about tripod choice mikeodial Pentax K-5 13 05-19-2014 06:46 PM
confused about macro lens happyprince Pentax K-5 9 02-25-2013 12:45 PM
Best lens caps and filters? natureshot12 Pentax Camera and Field Accessories 3 01-25-2013 02:56 PM
Lens caps and filters for DA Limiteds? Yohan Pamudji Pentax SLR Lens Discussion 10 04-22-2009 09:07 PM
lens hoods, lens caps, UV filters and camera storage Ed in GA Pentax SLR Lens Discussion 4 12-22-2007 01:40 PM
All times are GMT -7. The time now is 04:47 PM. | See also: NikonForums.com, part of our network of photo forums!
