01-25-2015, 08:07 PM   #1
Pentax 67 battery
some film negatives are gone or 1/4 are visible like shooting flash with over sync speed. I'm guessing that the weather cause this problem. Is there any way to prevent this problem?
01-25-2015, 11:34 PM   #2
Sounds like curtain travel time issues ( Both shutter curtains need to travel at the same speed or you can get uneven exposure or partially blank negatives). You need the appropriate test equipment to fix the problem which means it must be sent to your favorite Pentax repairman for a CLA.
01-27-2015, 10:50 AM   #3
My opinion, you should buy a new one . Just kidding )).
I agree with pentaxus, you need an appropriate equipment to fix this.
01-27-2015, 11:40 AM   #4
QuoteOriginally posted by sunshine7913 Quote
Prevention is not the solution. I would suggest correction. Your shutter (and probably the entire camera) is in need of service.
camera, pentax help, photography, troubleshooting
67 lens with 67 extension tubes on 645d fatboy22 Pentax Medium Format 3 06-28-2014 04:44 PM
P645NII, 67>645 Adapter, 67 Auto Extension Tubes? ASA32 Pentax Medium Format 4 05-24-2013 09:27 AM
All times are GMT -7. The time now is 01:25 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
