01-28-2015, 03:23 PM   #1
bright white outdoor pics
at this point I am really only using auto setting. took a seminar and have some high school photography experience 25 years ago to get back to using some of the manual settings.
in auto all of my outdoor shots are so bright they are almost white. I just reset my default settings but it did not help much. What should I look to change? any help would be great. Thanks, Ryan
01-28-2015, 03:29 PM   #2
Can you post a sample photo with exif intact?
Also, make sure your camera is set to matrix metering rather than spot or center-weighted.
01-28-2015, 04:24 PM   #3
jatrax's Avatar
And mentioning what camera and lens you have would help too.
01-28-2015, 07:38 PM   #4
Overexposed images could be settings or a stuck aperture. +1 that we need to know which camera and lens, plus a sample image.
01-28-2015, 10:01 PM   #5
This assumes you use the kit-lens (18-55) and it can be used to check the aperture mechanism in the lens and the aperture activation mechanism in the camera.
Switch to Av, set the aperture to f/8 or f/9.5 and take a picture of yourself. Keep the camera at arm length from yourself, point the lens towards you and look in the lens; you should see a small circle in the center of the lens. Take a picture while looking in the lens; do you see the small circle inside the lens changing while the picture is taken? If so, your aperture mechanism in the lens and the activation in the camera are OK; if not, the aperture mechanism in the lens and / or the activation in the camera is broken.
If the aperture works OK, we can check other settings. As the others said, post a resized picture with EXIF intact.
01-31-2015, 07:36 AM   #6
TaoMaas's Avatar
My first thought was that your ISO was set so high that there was no aperture/shutter speed combo on the camera that could make a proper exposure. But if you reset to the default settings, that should have cured that, I would think.
01-31-2015, 10:37 AM   #7
FrankC's Avatar
My first inclination was that your exposure compensation was probably set to +3.
auto, camera, help, pentax help, photography, settings, troubleshooting
Flash at outdoor pics rlatjsrud Flashes, Lighting, and Studio 5 11-25-2013 11:13 AM
K20D Long exposures bright white Jacho Troubleshooting and Beginner Help 9 01-13-2010 04:06 PM
Outdoor Black and White Portraiture Suggestions mk07138 Film SLRs and Compact Film Cameras 3 06-23-2009 03:14 PM
3 pics from an outdoor wedding thosan Post Your Photos! 7 06-27-2008 10:59 AM
bright/natural vs. white balance mattdm Pentax DSLR Discussion 3 05-18-2008 01:27 PM
All times are GMT -7. The time now is 09:50 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
