Originally posted by JinDesu <snip>
The Nikon Coolpix A is similar to the GR, as I said before, and both have dedicated integral lenses that make them as sharp as possible.
<snip>
The Coolpix will also have in-camera processing designed to produce a sharp output. In contrast there is usually no in-camera processing (including sharpening) applied to a RAW (DNG or PEF) file.
Set your camera to RAW+ e.g. so it creates both a PEF/DNG and a JPG. Set the size of the JPG to be the same as the size JPF produced by the Nikon. Now you are starting to compare apples with apples, though of course the processing the K3 does will differ from that of the Nikon.
I see there's another insult above as well, 'amateurs'. You are not being picked on, you are so convinced you are right that there is something wrong with the hardware that your mind is closed to any other explanation in which case why did you bother posting here?
