02-10-2015, 02:56 PM   #1
MJSfoto1956's Avatar
Just got K-3 back from repair...
So I just had my K-3 serviced by Precision for the "mirror flap" issue.
I cannot report yet whether or not this is fixed but in the meantime something else has come up.
No matter what lens I attach to the body, if I gently attempt to rotate the lens back and forth (even though it is locked, there is a very small amount of movement) the LCD screen blanks out (i.e. it goes black). This is true for my DA* 60-250mm as well as my Limiteds.
I did a quick search on Google but didn't come up with any good discussions -- but I have to believe that this has indeed been discussed before.
Appreciate your thoughts.
Michael
02-10-2015, 03:04 PM   #2
Not a Number's Avatar
I would check to see if the lens mount is screwed down securely.
02-10-2015, 03:05 PM - 2 Likes   #3
UncleVanya's Avatar
I would be sending that puppy back with a note that something is terribly wrong.
02-10-2015, 03:07 PM - 1 Like   #4
JinDesu's Avatar
That don't sound right. I've jiggled my k-3 and lens before and never encountered such an issue.
02-10-2015, 03:59 PM   #5
rburgoss's Avatar
As said: check mount bolts for tighness. If problem continues, try calling and reporting problem immediately. Then, pack and send back.
But before packing, try to recreated the mirror flop problem, just for piece of mind.
Let us know your findings and final outcome.
02-10-2015, 05:14 PM - 1 Like   #6
What he says.
02-10-2015, 05:21 PM   #7
the screws were just a VERY tiny bit "not quite fully tight" -- so I lightly tightened them. Precision says they upgraded the K-3 to firmware v 1.11 (but I am 100% sure I verified that it was v1.11 prior to shipping to them).They said they readjusted things and it appears that my lenses are now in focus with no micro adjustment necessary -- need to verify this. I have not extensively tested the repaired camera with regard to mirror flopping. Until I am 100% satisfied, I will continue to hold onto this camera until I can say with confidence it is fixed or not. This other "black LCD screen" issue may or may not be related. It also might be related to the Pentax battery grip as I have not had any issues with "black LCD screens" without it. At the moment, there simply are too many variables and I need to be more methodical to try to isolate the behaviors. More later.
Michael
02-10-2015, 05:44 PM   #8
You may want to check the tightness of the two gold contacts that transmit lens and AF info, both on the lens and on the mount. If the one that carries the lens info is intermittent all kinds of weird stuff ensues.
Jack
02-10-2015, 06:19 PM   #9
UncleVanya's Avatar
QuoteOriginally posted by MJSfoto1956 Quote
Michael
That firmware bit is common to their repairs. My K-50 also had been "upgraded" to latest firmware despite already having it when mine was in for repair. I think they just do a firmware refresh with latest as part of their normal process.
camera, k-3, lens, pentax help, photography, troubleshooting
Just got my K-3. Two questions for you guys please TrailRunner Pentax K-3 28 11-27-2014 05:37 AM
Just got my K-3!!! ChuckB28 Pentax K-3 2 06-22-2014 04:20 PM
Got my K-3 back from the workshop... Tjompen1968 Pentax K-3 2 12-15-2013 09:49 AM
Just got back from Niagara Falls Photochop Post Your Photos! 11 03-21-2007 09:41 AM
Just got back from the Studio benjikan Post Your Photos! 29 02-20-2007 12:59 AM
All times are GMT -7. The time now is 06:17 AM. | See also: NikonForums.com, part of our network of photo forums!
