02-10-2015, 07:28 PM   #1
Pentax k-x SD Card Formatting Help
Hello, I have a Pentax k-x DSLR camera that I recently bought over Amazon. When it came, I had no SD card to use with it. Wanting to jump right in, I inserted an old 8 GB Lexar card that I had used on multiple other devices. It worked great! I finally got around to buying a 64 GB Lexar card today, but when I went to reformat it the camera showed a loading bar for a split second before displaying "Memory Card Error." I've switched lenses, replaced the batteries, checked to make sure the sd card wasn't locked, and reformatted it directly on my computer. Nothing seems to be working. The card shows up fine on my Mac. When inserted into a 3DS, it couldn't even detect it. Any help would be appreciated, thank you!
02-10-2015, 07:43 PM   #2
K57XR's Avatar
QuoteOriginally posted by RealPotato Quote
Try this link. See post #9.
https://www.pentaxforums.com/forums/58-troubleshooting-beginner-help/191893-l...-card-k-x.html
What firmware do you have with your K-x? (Press and hold Menu then turn the camera on. It should show the fw version).
02-10-2015, 07:43 PM   #3
Emperor and Senpai
VoiceOfReason's Avatar
Have you updated your firmware to the latest on your Kx?
02-10-2015, 08:04 PM   #4
QuoteOriginally posted by K57XR Quote
I have version 1.01, 1.03 is the latest right? I'll try to update it and see if that fixes the problem.
02-10-2015, 08:14 PM   #5
K57XR's Avatar
Yes, I believe 1.03 is the latest. If you haven't done a firmware update before I suggest read the instructions carefully before proceeding, as this can potentially "brick" the camera if something goes wrong during the update process.
Good luck!
02-10-2015, 08:17 PM   #6
Good luck!
It formatted the card! Thank you so much for helping me!
02-10-2015, 09:05 PM   #7
K57XR's Avatar
good to hear!
camera, card, error, formatting, gb, help, k-x, k-x sd card, kx, lexar, memory, pentax, pentax help, pentax k-x sd, photography, sd, sd card, troubleshooting
SD card formatting issue kenneth7379 Troubleshooting and Beginner Help 12 04-24-2014 09:35 AM
SD Card formatting? Brownie4u Digital Processing, Software, and Printing 5 05-23-2013 02:23 PM
SD card not formatting Linda Gillespie Visitors' Center 2 03-03-2013 09:46 AM
SD card formatting fredok1 Pentax DSLR Discussion 29 04-01-2012 06:02 AM
Problem formatting PNY SD HC card in K10D Green_Manelishi Pentax Camera and Field Accessories 10 03-10-2009 06:47 PM
All times are GMT -7. The time now is 02:40 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
