Originally posted by Tired Old Man In Record menu, I set lens to 200mm (1.5x135)
Not related to your problem, but you should set it to 135mm (the actual focal length).
---------- Post added 13-02-15 at 06:26 ----------
Originally posted by Tired Old Man I configured spot AF with manual settings & can hear focus bell sound on distant subject
The (PDAF) AF system has a range where it will indicate that a subject is in focus; you can easily experience this by (very slowly) slowly turning the focus ring till you hear the beep and next (very) slowly continue to turn the focus ring while observing the green hexagon. It will stay on for e.g. the first degree (or so) that you turn the focus ring.
It takes practice to find the exact point. If your camera supports live view, that can be an option to use. Alternative is to use a third party split prism screen (Katzeye, focusingscreen.com) or Canon EE screen; you might need to shim (calibrate) it.
