Originally posted by soycory When does it become advantages to upgrade a body
I will echo what other posters have said, but I will point out that much will depend on which specific older body you are upgrading from, and which features you use. Some newer features can greatly improved your shooting experience, though they may not improve image quality directly.
In my own case, about 2 years ago, I upgraded from a K200D to a K30. Both are mid-range bodies, and they both cost me about the same amount of money.
What 'gains' have I noticed in going from the K200D to the K30 ?
- higher resolution
- better low light performance
- better autofocus ( not sure - I don't push AF to the limits )
- larger image buffer and faster write speed
- 2 control wheels
- better viewfinder
- TAv mode
What does the K200D offer that the K30 doesn't?
- top LCD display
- better DOF preview implementation
Note that for most of those differences, only the first 2 have any direct impact on the actual image, and depending on the kind of shooting you do, they may or may not have a big impact. The rest are "usability" factors, and of them, 2 of the big advantages of the K30 ( viewfinder and dual control wheels ) are available on the K10D, which is older than the K200D.
If you look at some of the older and/or lower tier models, you would find some bodies that don't include in-body SR, or that don't have WR. So it very much depends on the cameras you are comparing, and how important those various features are to you and the type of shooting you do.
If you ignore these "usability" features of the camera bodies, the quality of the glass becomes more important because it has a more direct impact on image quality.
For the kind of shooting I do, my K200D creates almost as good images as my K30, but in low light, it's no contest. However, all those other features, especially the better view finder and 2 control wheels, improve my shooting experience, and may indirectly result in me getting better images than I might get otherwise.
