02-15-2015, 02:00 PM   #1
K5iiis top lcd fade
The top lcd of my K5iis fades out or dims when the front of the camera is raised up a bit. The battery is fully charged and the camera is working just fine.
Is this normal? The camera is still under warranty. Thanks. Mike
02-15-2015, 09:00 PM   #2
sterretje's Avatar
Does the viewing angle change (from your eye to the camera)? If so, it's probably normal.
02-15-2015, 09:33 PM   #3
Just1MoreDave's Avatar
If I look directly down on mine and tip the front of the camera up, mine does get dimmer. Tip the front of the camera down and it doesn't fade until the angle makes the numbers hard to read anyway. My K-7 is the same exactly.
02-17-2015, 04:28 PM   #4
Thanks for your replies. According to a customer rep at Ricoh Imaging, whom I contacted, the lcd is designed to fade as described above. Mike
02-19-2015, 02:06 PM   #5
TER-OR's Avatar
LCDs are very angle-dependent, at least this type. They're also really hard to read with polarized sunglasses!
camera, k5iiis top lcd, lcd, pentax help, photography, top lcd, troubleshooting
Top-down LCD viewer - Shoot from the hip Plainfaced Pentax K-01 15 12-18-2013 11:34 AM
K-5 Cracked Top LCD SPO Troubleshooting and Beginner Help 14 12-02-2013 03:30 PM
K5 IIs Top LCD display viewing angle issue RGold Pentax K-5 5 11-23-2013 11:16 AM
Top LCD problem lister6520 Pentax K-3 5 11-19-2013 01:03 PM
Pentax SF10 top lcd cracked Tonytee Pentax Film SLR Discussion 2 03-24-2013 03:39 PM
All times are GMT -7. The time now is 08:22 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
