02-19-2015, 06:21 AM   #1
K100 D - Focus But No Lock
It's been a while since I've used my K100 D but the snow this morning looked beautiful on the trees and I wanted to take some pictures.
But I am having a problem. My lens (44mm Limited Pancake) will focus just fine outside, but I can't get a lock on anything. I tried all the different modes, from Automatic to Manual to Snow Scene, and it just won't lock outside. It works fine inside, but not outside. I don't know if there's a setting that's keeping it from locking because it's too bright or what. If I focus outside and switch it to manual focus, it will fire. But the hexagon just flashes no matter what I do in auto-focus mode, even though it does auto-focus.
I'm not sure what to do, as I haven't changed any settings on it since I haven't used it for months.
02-19-2015, 08:09 AM   #2
sterretje's Avatar
Are you using center point focus, select a focus point or do you let the camera decide? I suggest that you use center point so you know where to aim.
Is there sufficient contrast in the scene? Try to find something in the scene with sufficient contrast in the () area.
02-19-2015, 09:12 AM   #3
aleonx3's Avatar
QuoteOriginally posted by jcleary47 Quote
It is likely not a focus issue, in auto-mode the camera will not allow you to trip the shutter if something such as the shutter exceed the max range - the camera should be flashing.
auto-focus, camera, focus, k100, k100 d focus, lock, pentax help, photography, snow, troubleshooting
K100 D Super Autofocus Liney Troubleshooting and Beginner Help 3 08-03-2014 01:03 AM
Pentax K-10 D Makes noise and No Auto Focus ? stevewong Pentax DSLR Discussion 9 06-17-2014 11:28 AM
Question about focus lock indicator on manual focus lens jostafew Pentax K-r 6 07-24-2013 10:50 AM
No focus lock DennisH Troubleshooting and Beginner Help 3 07-14-2013 07:14 PM
Exxxotica in Miami! (No nude photos, but you'd better be 18+) Sleepy Post Your Photos! 5 05-27-2009 09:06 PM
All times are GMT -7. The time now is 12:56 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
