Originally posted by mee TAv has its negative though.. and a big one.. that is it will tend to pick a high ISO value from the range you give it if your light isn't 'ideal' (for the camera).
It's not a matter of 'tend to pick a high iso', the camera does not have any options! You fix two parameters, so it needs to adjust the third one. Slow or fast adjustment does not play a role here, that's only applicable when the camera can choose two parameters (e.g. shutter speed and iso).
This is my understanding how it works.
Originally posted by mee And these APS-C bodies aren't super fantastic at low noise at high ISO (comparatively at least).
Wait till you used a CCD based camera (e.g. K100D or K10D) and you will never complain again
It's always a balance; FF also has limits although a bit further away
Do you want the shot and accept the noise, or do you not want the shot.
