02-22-2015, 06:07 AM   #1
shutter speed
A strange thing happened yesterday. I turned on my k 50 and could not adjust the shutter speed over 1/30 of a sec,Was working fine the day before. Changed from manual to auto and back. But would not go over 1/30. I went in to the menu and hit reset and all is good. Is this just a glitch that happens sometime. I have only had the camera a few months and still have a lot of learning on it.
02-22-2015, 11:47 AM   #2
This is the expected behavior in Tv and P (Tv Hyper) modes when there is inadequate light for a particular ISO setting. In other modes, this should not happen.
Note: Yesterday when I posted, Tv mode on the K-50 I had in hand did cap the shutter speed in dim light. Today it did not...go figure...
02-23-2015, 07:30 AM   #3
thanks for the response i will keep and eye on it. Hopefully it was a one time thing.
02-23-2015, 08:05 AM   #4
QuoteOriginally posted by cdcdx1 Quote
In Manual mode you should be able to set the shutter to whatever you want (likewise for Tv mode).
So possibly a dumb question but also possibly what your problem was- did the display read 30 or did it read 30"? The " marks would indicate you're at a 30 second shutter speed, which you cannot pass (without bulb mode). Without the " marks, you'd be at 1/30 of a second. Put it in manual mode and try wheeling the shutter speed to both extremes and watch where the " tag appears.
02-23-2015, 09:29 AM   #5
QuoteOriginally posted by BrianR Quote
My mistake regarding the Tv behavior. I had the K-50 in hand when I wrote my previous comment, but this morning Tv allows any setting. P (Tv Hyper) still caps the shutter speed based on the ISO, however. Perhaps I was seeing the same issue as the OP?
I will edit my comment.
02-23-2015, 05:05 PM   #6
Just1MoreDave's Avatar
My idea is that an e-dial was not working properly. Some older cameras have had this issue - I fixed my brother's K-r recently with contact cleaner. It's unusual in a newer model just because they haven't collected enough debris. If that's it, it will stick on any adjustment made with that dial. Often one direction works and the other direction doesn't. Spray some electronics contact cleaner around the dial, spin it a few times and that clears it up.
02-24-2015, 09:29 AM   #7
QuoteOriginally posted by Just1MoreDave Quote
I did have it in manual and it was at 1/30 i could go to 1/15 and longer but not higher. It hasn't done it again so i an hoping it was just a one time glitch.
camera, pentax help, photography, shutter, troubleshooting
Pentax MX shutter speed indication repair RolleiJo Pentax Film SLR Discussion 4 01-20-2015 04:37 PM
Limit shutter speed with flash hidden_au Pentax DSLR Discussion 5 11-13-2014 05:27 PM
Jumping shutter speed in exposure mode P ? siegbert Pentax K-3 14 10-07-2014 11:38 AM
Can't set shutter speed JLM Troubleshooting and Beginner Help 4 08-16-2014 04:01 PM
lumens/EV/f-stop/shutter-speed? tripodquest Flashes, Lighting, and Studio 2 11-10-2013 08:49 PM
All times are GMT -7. The time now is 11:06 AM. | See also: NikonForums.com, part of our network of photo forums!
