02-22-2015, 07:19 PM   #1
Yarddog's Avatar
K100D shutter release not working
Shutter release button will not work if the flash in up. the button/camera works fine as long as the flash in in the down/off position. Any suggestions on what the problem might be? The camera is a K100D with a shutter count of 3600.
02-22-2015, 07:54 PM   #2
calsan's Avatar
Unfortunately, the flash circuit of the built in flash must have died.
Options are to either:
* fix the camera - but at what cost - probably higher than replacement second hand?
* Get an external flash and use that when you need flash - the camera should work with the external flash.
* replace with like camera or slightly better model second hand. Check the marketplace.
* New camera
02-24-2015, 02:39 PM   #3
Yarddog's Avatar
QuoteOriginally posted by calsan Quote
* New camera
Went with external flash option, for now.
02-25-2015, 07:58 PM   #4
QuoteOriginally posted by Yarddog Quote
Did you try to set "Release when Charging" in the Custom Setting Menu? The default is OFF. This should allow you to use the camera with internal flash is up regardless if flash is working or not.
camera, flash, k100d, k100d shutter release, pentax help, photography, release, shutter, troubleshooting
K-5 shutter does not release lubibubi Pentax K-5 7 04-12-2014 09:47 PM
K100d not working Jimmy Troubleshooting and Beginner Help 16 01-13-2014 04:12 AM
Help! MZ-7 shutter release not working Black Magic Pentax Film SLR Discussion 9 08-12-2009 08:56 AM
K10D shutter release button not working well . Any ideas lesmore49 Pentax DSLR Discussion 6 07-19-2009 10:48 PM
Shutter release not working K10 voicelit Pentax DSLR Discussion 10 06-05-2008 12:44 PM
All times are GMT -7. The time now is 06:18 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
