02-26-2015, 06:58 PM   #16
QuoteOriginally posted by DeadJohn Quote
I understand the behavior you describe. I'm surprised any company wasted time engineering that feature, which is more difficult to implement than a consistent AF method that doesn't need to know the aperture setting.
Well, that's the question -- does it actually affect the AF or just the green hexagon? I noticed it because I was tweaking the AF adjustment on the lens using the "dot-tune" method where the focus confirmation is important and noticed that it mattered what I had the aperture set to, e.g. if I were to set it to f/22, it probably would have confirmed any near focus, but at f/2.8 it had to be spot-on. (So if you use the dot-tune method, make sure you keep the aperture setting on the max aperture.)
accuracy, accuracy with da, af, af accuracy, camera, center, da, error, f5.6, focus, k-3, k-5, lens, lenses, pentax help, photography, repair, time, tree, troubleshooting
Strong Back Focus issue with all AF lenses but not with MF lenses tempelorg Troubleshooting and Beginner Help 5 07-01-2014 07:18 AM
Q adaptor aperture accuracy with non A lenses? Lowell Goudge Pentax Q 3 03-28-2013 02:44 AM
AF and focus accuracy using older firmware vs. new (1.03) on K5 plus DA*300 jpzk Pentax K-5 65 05-13-2011 12:35 PM
K5 and AF accuracy with Sigma 17-70mm HSM lens amvic Pentax K-5 18 11-20-2010 12:18 PM
AF Accuracy's Dependency on Lenses and Yellow Light RiceHigh Pentax DSLR Discussion 10 02-19-2007 06:51 AM
All times are GMT -7. The time now is 10:54 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
