Originally posted by Trigger Happy If the contacts on the body don't make good contact to short out on the lens mount then the K-30 for sure (and I assume the K-50 as well, since they're very similar) will not meter with the green button in M mode unless you're in live view. You can test this with an M42 lens that doesn't short out the body contacts, or with no lens, to see if it's the same behaviour.
Not sure about the front wheel not working.
What he said.
Clean the face of the mount on the lens with alcohol and see if that does not help things a little.
