Originally posted by stevebrot ...or having the A-contacts. If the "A" contact ("*" in diagram below) is not detected, AF will not be attempted.
It's good that the OP found a cure, but I feel compelled to add a post because I believe this statement is not accurate. IIRC the "A" contact transmits aperture information (min/max and Av from the lens if the aperture ring is set to "A").
The "Data" contact, which is the bottom-most of the
seven body contacts (and not shown in the above diagram), transmits the rest of the lens info (model, screw drive/SDM, MTF in FA and later models, etc). If this contact is not functioning correctly, then the body can assume an MF lens is mounted.
Scott
