03-07-2015, 08:54 PM   #1
K3 stuck in MF
I hope the brains trust can help here.
The body switch does nothing. I've done a functions and settings reset. When a different lens is attached on startup the camera asks what length it is.
What preceded it: I had on a Sigma lens that's worked fine lots of times and this time I switched it to MF using its own setting. When I switched to the 18-135 Pentax lens focus was stuck on manual in the body settings.
03-07-2015, 09:10 PM   #2
Reverse the spell by putting the Sigma back and switching it to AF?
03-07-2015, 09:17 PM   #3
VoiceOfReason's Avatar
Check to see that nothing is on the contacts. Perhaps clean them.
03-07-2015, 09:27 PM   #4
Thanks folks.
Yeah I tried reverse magic. Not the right phase of the moon maybe.
And yes, cleaned the contacts too.
03-07-2015, 10:46 PM   #5
Turn off the camera. Remove the lens. Turn on the camera. Watch the focus lug on the mount when you move the switch between AF and MF. It should extend when in AF and retract when in MF. If this does not happen then something has broken or you have run out of power.
03-07-2015, 10:47 PM   #6
It is strange. Try the usual. Take the battery out for a bit, flip the AF/MF switch back and forth a few times, try a total reset of the camera to default settings, etc. I hate to think the body can be persuaded to be MF only simply because a Sigma lens told it so. If it did, resetting would probably clear it...
03-07-2015, 11:21 PM   #7
Thanks again.
Focus drive pops out OK. Removed battery - no change. But there must be non-volatile memory for user settings. Will look for more reset options.
03-08-2015, 12:30 AM - 1 Like   #8
rburgoss's Avatar
Try reflashing firmware on body. Check version and upgrade if necessary.
By all means, let us know your findings.
03-08-2015, 01:43 AM   #9
Yes, I was fearing it might come to that. Awkward when travelling. The firmware is current but a reflash might be the equivalent of "format c:"
03-08-2015, 01:29 PM   #10
Firmware updated. No change.
A search threw up some other possibilities and responses* but I got no traction: alignment of AF drive screw with lens body, and quality of batteries.
However the drive screw on my body does show noticeable slop. Would someone be kind enough to check theirs?
[* https://www.pentaxforums.com/forums/58-troubleshooting-beginner-help/229309-k...t-working.html
https://www.pentaxforums.com/forums/58-troubleshooting-beginner-help/198424-k...ocus-mode.html ]
03-08-2015, 06:27 PM   #11
rburgoss's Avatar
Have you tried a non DC or SDM original pentax lens? (FA or F???)
Since you say the body is asking for focal length upon mounting, this means body is not recognizing the lens as being autofocus. Pentax has three possibilities for autofocus lenses. F (FA) with no motor, just screw drive; DA with both screwdrive and internal SDM motor and just DC motor, as the 18-135. Try to test one of each just to pinpoint where is the problem coming from.
I am afraid the Sigma has something to do here, but hopefully, it would be just a software bug and not something that got shorted or burned.
Keep us posted please.
03-08-2015, 07:17 PM   #12
Otis Memorial Pentaxian
QuoteOriginally posted by rburgoss Quote
...or having the A-contacts. If the "A" contact ("*" in diagram below) is not detected, AF will not be attempted.
Edit: I don't know where my head was at when I typed the above, but the F-- display by itself means that the "A" contact was not detected. AF should still work if the data pin (not on the diagram) is still operational. If both are dead, it would be evidence that the lens is not fully mounted or that the lens chip is not proper or that their is a fault with the body.
03-08-2015, 08:54 PM   #13
Thanks rburgoss.
Apart from the 18-135 there's a DA 12-24. Same issue. The Sigma is a 150-500 and that's HSM. So I guess that means the fault isn't (just) mechanical.
Thanks Steve. The body has 7 contacts. The 3rd from the top is recessed but still spring loaded. I've given it a clean & a 'tickle'.
03-08-2015, 10:02 PM   #14
Woah. 2nd & subsequent lens swaps have AF enabled. Phew. Looks like attending to the * contact did it.
Thanks again all.
There's two weeks of shooting in god's own country ahead.
03-09-2015, 06:01 AM   #15
rburgoss's Avatar
Whew... thnk God nothing was wrong. Just probably some minuscule debris caught in the third mount contact. I would check all my lenses mounts fot debris and grime spots. I'm sure your problem was created by something transfered by a "dirty" lens mount.
Thanks for sharing this. I am sure this information will become very handy any time soon, for every Pentax user out there.
aperture, body, camera, contact, lens, mf, pentax help, photography, post, scott, settings, thanks, troubleshooting
645 adapter stuck on k3 mccarvindh Pentax K-3 & K-3 II 6 03-14-2014 07:06 PM
AF/MF button stuck mde1970 Troubleshooting and Beginner Help 4 08-27-2012 02:32 AM
KX stuck in autofocus, but switch is stuck in MF icywarm Troubleshooting and Beginner Help 4 08-07-2012 07:21 AM
k100d MF/AF toggle switch stuck in MF summatusmentis Pentax DSLR Discussion 9 11-26-2009 03:52 PM
New to K10D stuck with MF istDL-K10D Pentax DSLR Discussion 21 10-17-2008 10:13 AM
All times are GMT -7. The time now is 03:00 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
