03-08-2015, 03:06 PM   #1
K5lls + 100 Macro issues
A friend has a K5lls and a Pentax 100 Macro (latest edition) and with this combination, the monitor info just shows MF letters, no F stop just two blinking dashes, just iso and the rest of the screen shows no other info and the monitor screen is blank and kind of dark.
She has tried her other lenses (55-300) on the K5lls body and they work fine...with all info showing on the monitor body.
It's just the 100 macro on the K5lls.
Now when she tries the 100 Macro lens on her KX body the macro and camera works fine.
Any suggestions ?
03-08-2015, 03:12 PM   #2
jatrax's Avatar
I assume this is DFA 100 macro WR? Or at least the version with no aperture ring? If not then make sure the aperture ring is in the 'A' position.
Other than that, getting "F _ _" means the camera does not know there is a lens on because it cannot read the lens ID. That is almost always a contact issue. So try cleaning the contacts, a buffing with a microfiber cloth should be all it needs.
If that does not work, take a careful look at the contacts on both camera and lens and make sure they all look correct.
When you say "KX" do you mean the k-x or the film body?
03-08-2015, 03:19 PM   #3
I assume this is DFA 100 macro WR? Or at least the version with no aperture ring? The WR without the aperture ring. If not then make sure the aperture ring is in the 'A' position.
Other than that, getting "F _ _" means the camera does not know there is a lens on because it cannot read the lens ID. That is almost always a contact issue. So try cleaning the contacts, a buffing with a microfiber cloth should be all it needs. I will suggest that she try that.
The K-x digital slr camera. Not the old film slr. The one that was introduced a couple of years ago.
Thank you for your suggestions.
03-08-2015, 03:29 PM   #4
jatrax's Avatar
QuoteOriginally posted by lesmore49 Quote
What I figured but wanted to be sure in case there was something with a film body I was not aware of. But the k-x and k5IIs should behave identically. The only thing I can think of is that there is some small amount of tarnish on the k5IIs contacts that is causing the communication failure.
It could also be a slight misalignment of the contacts but that is highly unlikely on a Pentax lens. I have seen it on third party lenses though.
03-08-2015, 05:13 PM   #5
A big thank you to both jatrax and dcshooter. My friend cleaned the contacts and as they say in France...'voila'....the K5lls and 100 WR macro are once again making music.
Les
body, camera, info, k5lls, k5lls 100 macro, macro, monitor, pentax help, photography, screen, troubleshooting
Issues with K-01 + DA35 Macro? luftfluss Pentax K-01 7 11-03-2014 05:50 PM
K5lls and Katzeye screen TaiChiTom Pentax K-5 7 08-14-2013 10:32 AM
Focusing issues with Sigma 105mm macro cam541 Pentax K-01 4 06-02-2013 06:20 AM
D FA Macro 100 / Tamron 90 Macro: Good for events? EarlVonTapia Pentax SLR Lens Discussion 22 05-16-2013 05:34 AM
Sigma 100-300mm f/4 serious issues CWyatt Pentax SLR Lens Discussion 12 02-25-2010 02:29 PM
All times are GMT -7. The time now is 05:53 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
