03-08-2015, 09:45 PM   #1
Lightroom Lens Correction Rokinon 14mm?
Hi there,
I recently purchased the Rokinon 14mm F2.8 lens. Is there any way to download a lens correction profile for this lens? I don't see Rokinon listed the options at all.
Thanks.
03-09-2015, 03:15 AM   #2
bossa's Avatar
It's been around for quite awhile so I can't help but wonder why there isn't one. Perhaps Adobe requires payment for including one?
03-09-2015, 03:33 AM   #3
Na Horuk's Avatar
Which version of LR do you have?
First, Rokinon is just rebranded Samyang. Samyang makes certain lenses that then get sold as Bower, Rokinon, ProOptic, Walimex, Vivitar, Falcon, and others. Sometimes the same store sells the same lens with two different names, for different prices. But LR doesn't have lens corrections for any of them. Guess Adobe just doesn't care about this brand. But there is a lens profile utility, where users can make their own profiles.
You can search these forums, I uploaded a Rokinon 14mm lens profile to some thread. It is custom made by a forum member. The distortion correction works great for me.
03-09-2015, 07:06 AM   #4
If you download Adobe's Profile Downloader, there is a user profile for it under "Nikon D700 (Samyang 14mm f11)" -- works pretty good.
03-09-2015, 05:47 PM   #5
Na Horuk, thanks for the info. I'm using LR 5.
---------- Post added 03-09-15 at 05:48 PM ----------
VonBaloney. Thank you - I'll give it a shot.
03-09-2015, 06:00 PM   #6
QuoteOriginally posted by deanjef2 Quote
But you will have to manually choose it each time since your lens lacks the data contact to provide identification in the EXIF.
03-09-2015, 06:32 PM   #7
Yep. I wonder if I can change the name to at get it at the top of a list...haven't tried that.
07-22-2015, 03:18 AM   #8
Neville's Avatar
After downloading the file, how do I import it into Lightroom?
07-25-2015, 04:07 PM   #9
QuoteOriginally posted by Neville Quote
This link has the full steps:
Rokinon 14mm Lightroom Lens Profile - Sven Stork
But in short:
After downloading the lens profile you need to copy the file into the Lightroom lens profile folder. Depending on your operating system the folder locations are as follows (just replace [your user name] with your your username):
Windows: C:\Users\[your user name]\AppData\Roaming\Adobe\CameraRaw\LensProfiles\
Mac OS X: /Users/[your user name]/Library/Application Support/Adobe/CameraRaw/LensProfiles/
Usage
After the lens profile is installed you can use it with RAW files (JPEG files are currently not supported). The profile should work for any full frame camera. To activate the profile select the following values in the lens profile dialog:
camera, correction, lens, lens correction rokinon, lightroom lens correction, pentax help, photography, profile, rokinon, troubleshooting
Vivitar 14mm f2.8? Same as Samyang/Rokinon/Bower 14mm f2.8? buliwyf Pentax SLR Lens Discussion 18 05-14-2015 08:18 PM
Rokinon/Samyang 14 mm Lens Correction profile? uday029 Pentax SLR Lens Discussion 6 12-22-2014 03:49 PM
Samyang 14mm = Rokinon 14mm? steezylistic Troubleshooting and Beginner Help 9 02-13-2014 09:25 PM
Lightroom 3 will feature lens correction cezarL Digital Processing, Software, and Printing 17 03-01-2011 12:28 AM
Adobe Lens Correction Profile DA 14mm Sirfishalot Pentax SLR Lens Discussion 2 08-23-2010 01:38 PM
All times are GMT -7. The time now is 01:36 PM. | See also: NikonForums.com, part of our network of photo forums!
