03-17-2015, 11:17 AM   #16
If you set the ISO to a lower one, the camera thinks that the sensitivity is lower so it will ask for more exposure time or apperture, so you are OVERexposing. This is called "pulling".
You may check how much exposure tolerance does your roll supports. Some rolls have higher exposure tolerance than others. For example, I have a b&w film that is ISO 100 and can be pushed up to ISO 800 and pulled down to ISO 50, while other rolls I have that are also ISO 100 can only be pushed up to 200.
So what I recommend you is to know the lattitude range of your film because from iso 400 to iso 20 is a realy huge difference, and you have overexposed your film for 4 or 5 diaphragms, which is quite a bit, and you may be wasting money on negatives that will be completely white when positived.
You can know this information by checking the DX code in the roll.
The wikipedia webpage has some accurate info on this: DX encoding - Wikipedia, the free encyclopedia
camera, film, iso, iso 20, iso 400, k1000, k1000 shot, latitude, pentax help, photography, request, results, roll, shot, troubleshooting, wrong iso
Pentax Q - how to undo photo shot with wrong settings AndrewAllan Troubleshooting and Beginner Help 2 03-29-2013 05:44 AM
Iso setting on K1000 98dblachr Pentax Film SLR Discussion 8 06-05-2011 11:36 AM
Wrong ISO set on camera PeteStump Film Processing, Scanning, and Darkroom 7 05-06-2011 05:01 AM
Is something wrong with my K1000? thehof Pentax Film SLR Discussion 9 02-11-2011 12:40 AM
why use ISO 1600 in this Canon 5D street shot? WMBP Non-Pentax Cameras: Canon, Nikon, etc. 28 10-08-2009 10:52 AM
All times are GMT -7. The time now is 12:12 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
