03-13-2015, 10:17 AM   #1
Total Beginner to photography
Hi my name is Cotty and I am a total beginner to photography. I recently purchased a Pentax K50 and loving it. I am interested in purchasing a IR remote shutter release. Which is the best budget friendly one compatible with the k50? I read some reviews that said some of the remotes only work well during during low light conditions. Can the k50 be trigerred from behind.
03-13-2015, 10:34 AM   #2
gmans's Avatar
Welcome to the PF Cotty, I bought a cheapie IF ( <$10.00) off a local Australian Ebay and it works okay. Can not say on the K50, but have look on the back for a window for the IF, there is a darkish opaque plastic window for the IF port, its on the front on the grip side I think, so there should be a similar window on the back if at all.
Look forward to seeing your photography and there is always something to learn which is half the fun.
03-13-2015, 10:56 AM   #3
Thanks for the info. Will check for the if on the back.
03-13-2015, 11:04 AM   #4
Nowhere Matt's Avatar
I don't think the K-50 accepts any wireless remote; only a cable remote. Think about using the timer delay or you may find yourself searching for a cable remote.
03-13-2015, 11:09 AM   #5
QuoteOriginally posted by Nowhere Matt Quote
The K-50 can be triggered with IR remotes, but only from the front (Cotty, the receiver is the oval-ish window on the grip).
@gmans what does IF stand for?
03-13-2015, 11:17 AM   #6
gmans's Avatar
Got no idea? My lack of coffee is to blame and maybe A...G...E syndrome.
03-13-2015, 11:28 AM   #7
photolady95's Avatar
Location: Cruising PentaxForums and watching your back.
IF stands for Infra Red. And a wireless remote can be used with the K-50. The little window on the front is red. See this photo, look at the little oblong red window on the left facing you.
Pentax K-50 - Pentax K-mount DSLRs - Pentax Camera Reviews and Specifications
03-13-2015, 01:56 PM   #8
QuoteOriginally posted by Giklab Quote
Sorry that should have been IR not if
03-13-2015, 08:46 PM   #9
Correct. The IR port is on the front grip. It cannot be triggered from behind or the side using IR remotes, but you can get a wired remote for that. I have both wired and wireless, manufactured by JJC and each was <$10 USD from amazon. They both work just fine on the k-50. So far, I've not had any problems using the wireless remote during the day, but I haven't used it much during that time either, as I mostly shoot night landscapes/astro/starscapes, etc...
03-13-2015, 08:53 PM   #10
Aaron28's Avatar
if you put the camera in the remote mode....the ir sensor in front of the camera will blink....can not trigger from behind unless a mirror or 'reflector' of sort can bounce the signal......I got this one but from digital goja.................
Wireless Remote Control for Pentax 645D K M K 5 II s K 50 K 30 K 500 DSLR Camera | eBay
03-14-2015, 07:47 AM   #11
JimC1101's Avatar
Yeah it is the same method used in TV remote controls just as you can bounce it from the side and it will still get a signal and produce, but there is no back IF on the K-50.
03-14-2015, 08:51 AM   #12
mee
QuoteOriginally posted by photolady95 Quote
I think you mean IR not IF
IF is short for Induction Furnace, Ifosfamide, or IronForge among other things haha
03-15-2015, 04:26 AM   #13
Oldbayrunner's Avatar
QuoteOriginally posted by Aaron28 Quote
One can purchase a wireless remote with a trigger and a plug in receiver that can trigger the shutter from any position.
03-15-2015, 06:16 AM   #14
Aaron28's Avatar
well I stand corrected......and maybe such a device is budget friendly..................
beginner, camera, ir, k50, pentax help, photography, release button, shutter, troubleshooting
People Beginner Photography! Kikoy_Sauce Post Your Photos! 4 08-11-2014 02:20 PM
beginner to photography theman123 Welcomes and Introductions 8 03-18-2014 06:10 AM
Total Beginner, Aspiring Landscape Photographer BeginnerDave Welcomes and Introductions 3 01-30-2013 01:35 AM
beginner's guide to film photography? rpriedhorsky Troubleshooting and Beginner Help 4 07-13-2009 11:17 AM
All times are GMT -7. The time now is 12:59 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
