03-20-2015, 07:21 AM   #1
Camera settings advice needed
I'm needing some help. A friend of mine told me he has a fox den on his property and asked if I would like to go photograph it. Of course I said HECK YEAH. as my forum name indicates I'm new to digital. So here's the problem. The longest focal length lens I have is the SMC DA1:4-5.6 50-200mm ED WR. I have a Focal MC 2x converter. I know it doesn't support the auto focus. and I'm not sure what other problems I could run into. with the F- stops and such. what shooting mode should I set the camera at. should I raise or lower an f stop? I'd like to have the camera do as much of the settings as possible so I can concentrate on composition. This might be a day of learning but Its unlikely I'll get a second chance at these photo. any advice would be greatly welcome.
03-20-2015, 08:43 AM   #2
SpecialK's Avatar
It will likely be dim conditions, so I'd start at ISO 800 or so. Put the mode dial on P. The converter will make it almost impossible to see through the viewfinder, and you will probably get the same results through cropping the image a little.
03-20-2015, 08:50 AM   #3
Ok, thanks.. This should be fun.
03-21-2015, 05:07 AM   #4
savoche's Avatar
Don't be afraid of going to higher ISO values. The K-5 does quite well up to ISO 6400. Lower is always better, but noisy pictures can be fixed (to a certain extent). Blurring from too slow shutter speeds can't.
And I don't think I would use the converter in low light. It eats too much light to be of much help.
Good luck!
03-22-2015, 06:35 AM   #5
Ok.. I was wondering about the loss of light I know on my old manual body it was a problem..
03-24-2015, 07:31 PM   #6
Paleo Pete's Avatar
I agree I would leave the teleconverter off. I always start at f8, you might need to open up a little, but depending on light conditions you might be able to get ISO 800 at f8 to work pretty well. Get as close as you can without disturbing them. We have a fox living around here somewhere but I haven't found where yet. I've seen one run by several times, never got a shot so far...I'm wondering if a flash might be useful...I know it will get red eye, but might light things up, that's a really low light situation otherwise.
03-25-2015, 12:12 AM   #7
These are living in a ravine. I might be able to get above them but that still won't help the low light problem.
advice, camera, camera settings, camera settings advice, help, pentax help, photography, settings, troubleshooting
Advice needed for busy multi camera shoot gsrokmix Video and Pentax HDSLRs 11 06-21-2014 06:48 PM
My Camera is ready for its 100,000-mile checkup (Advice needed) charlestm Pentax DSLR Discussion 4 05-30-2013 06:30 PM
New Camera - Something Wrong - Advice Needed Please ! NCGirl Pentax DSLR Discussion 12 11-26-2010 07:06 PM
Advice needed - selling camera system rae2 Photographic Technique 5 12-18-2009 07:34 PM
Off camera flash advice needed gawan Flashes, Lighting, and Studio 24 02-24-2008 03:52 PM
All times are GMT -7. The time now is 09:51 PM. | See also: NikonForums.com, part of our network of photo forums!
