03-20-2015, 07:26 AM   #1
Newbie help with MZ-M
Hi, I've just bought myself a Pentax MZ-M, I found the user guide online and have been fiddling about with different settings but now I can't seem to get it off the manual ISO setting :-/ I've tried the manual but can't seem to find a solution. Any help would be very gratefully received!
03-20-2015, 10:43 AM   #2
blackcloudbrew's Avatar
I'd like to be of help as I had one of these several years ago and a quick look at the manual reminded me that the ISO setting dial was a bit tricky.
As I recall, it's made to get the ISO setting from the film canister which most modern film cans are DX type with the appropriate encoding. So your question about getting it off manual ISO setting is puzzling. Did the ISO not get set when you loaded film? Or did you change it from what it was set to and want to go back to automatic? I'm sort of puzzled at your problem. In in looking at p15 of the manual clearly you can override the camera auto ISO setting or if none is recognized, set it manually. If you just want it to go back to auto load a new roll of film (I think). Anyway, can you be a bit more specific about what problem you are having?
03-20-2015, 03:17 PM   #3
QuoteOriginally posted by Victim77 Quote
Hi! Welcome to the Pentax Forums!
The procedure is in the manual on page 15. From what I can tell, the steps are as follows:
  • Turn the exposure compensation to either the up-arrow (to increase) or down-arrow (to decrease) position while holding down the exposure compensation dial release (center of dial)
  • Depress the memory lock button (to right of viewfinder) until the desired ISO is displayed in the top LCD
  • Return the exposure comp dial to the zero position
BTW: This the first I had was aware of this very cool feature that should allow use of non-encoded film canisters.
03-20-2015, 03:33 PM   #4
Thanks blackcloudbrew - I was exploring the settings, it was set to auto when I put the film in but I changed it and want to return to auto :-/
Thanks Stevebrot, I can change it that way but am unable to return it to the auto setting :-)
camera, help, mz-m, pentax help, photography, troubleshooting
Newbie needs help with K30 lawjie Pentax K-30 & K-50 15 04-24-2014 06:29 AM
Newbie needs help with flash FLkrakr Welcomes and Introductions 4 06-08-2013 04:11 AM
MZ-M Troubleshooting help VF-19 Pentax Film SLR Discussion 10 05-22-2009 06:16 AM
Need help getting MZ-M from the US Andi Lo Pentax Camera and Field Accessories 6 04-25-2009 03:41 PM
Newbie with K10D needs help! ctt Troubleshooting and Beginner Help 6 12-13-2007 07:47 PM
All times are GMT -7. The time now is 01:13 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
