Originally posted by ckschempp Another focus issue with my new k3 and I know it isn't the camera body b/c I already exchanged my first one, thinking that it WAS the body. So I have two lenses: A sigma AF 17-35 F2.8-4, and a rokinon 85mm F1.4 full frame lens. The sigma just can't seem to get a sharp focus, even with fiddling with the AF fine adjustment. Is this just a lower quality lens that I should trade up from?
The Rokinon is a dream to play with, except that once I dip below 5.6 aperature the focus is completely off. I will focus on a eye and get the shirt collar crisp as can be. The fine focus adjustment doesn't work b/c it is a manual focus only. I figure that the focal point is somehow off. Should I program in a different focal point at the start, other than 85mm, since it is a full frame lens perhaps? Any suggestions?
Working in live view seems to be accurate with the 85mm, but it's a pain b/c I have poor near-vision, and then I get camera shake having to hold the camera away from me to see the screen.
Anyway, I'm so frustrated, I'm wondering if it's just me, or if I should scrap pentax and go with canon, or if I need to invest in higher quality lenses just to get a crisp picture. My sony point and shoot is rendering cleaner lines than anything I'm coming up with right now
Please help?!?
BTW- this forum rocks, so I really don't want to scrap the whole thing.
The Sigma lens you have is not a good performer. Have a look here -
Tests and reviews for the lens Sigma 17-35mm F2.8-4 EX DG Aspherical HSM Canon mounted on Canon EOS 7D Measurements - DxOMark Granted the test is on a 7D but it will not perform any better on your K3. Notice that at any focal length and under f5.6 it is fairly mediocre as far as sharpness goes. The lens seems to be at its best at the wider end - 17mm but its still not sharp. Your K3 will bring that lack of performance out.
So my advice would be to retire it and get something better. Even the Pentax kit lens 18-55 will provide better performance. Compare here
Tests and reviews for the lens Pentax smc PENTAX DA 18-55mm F3.5-5.6 AL II mounted on Pentax K-3 Measurements - DxOMark
As to your Rokinon; unless you have a tripod and some patience it will likely frustrate you. That lens is a good FF portrait lens meant to be used in a studio setting. Ideally used tethered - something the K3 doesn't do. So put that one aside as well.
Your best choices would be to get the current generation 18-55 or if you wish the Pentax 35 mm f2.4 - either are inexpensive but better and easier to use than what you have. You can then enjoy your photography, improve your technique, explore the capabilities of your K3 and when you are ready step up to something more expensive and higher performing. If you have money burning a hole in your pocket you could try for the new Pentax 16-85 - that would be a tremendous step up in performance from where you are. If you are near a brick and mortar shop ask them to get one in for you to try.
Lastly it has been my experience that all my lenses (I have Pentax, Sigma and Tamron) require focus adjustment to reach their capability. You can read how to do it by doing a search on these forums. Also to really learn join a local photography club. There you will find many people that would be glad to help you in person.
